mac1as Posted March 11, 2011 Share Posted March 11, 2011 Hello everyone On the begining I want to apologise for my english, it isn't my primary language so please by tolerant, I won't be writing much instead of that I will try show more pictures. I want to show You my latest project "Acid Veins", some of You could see it on other forums, but for those who didn't enjoy. Main Components: DFI DK X58-T3eH6 Intel i7 920 OCZ 6GB PC312800 CL7 Sapphire HD R5850 + GeForce 9600 GT SilverStone Strider 1000W - ST1000 WC Components: EK Water Blocks EK-CoolStream RAD XT 240 EK Water Blocks EK-CoolStream RAD XT 360 Laing DDC-pump + Acrylic Top EK Multioption Reservoir Res X2 250 Basic "Veins" 10/13 EK Water Blocks EK-Supreme LT Acetal+Nickel NB - EK Water Blocks EK-NB/SB 5 Acetal EK Water Blocks EK-FC5850 Acetal + Nickel + EK Water Blocks EK-FC5850/5870 RAM Backplate - Black + EK Water Blocks EK-FC9600 SLI - Acetal VGA Block MIPS RAM cooler 5 incl. 3 RAM Module Nickel POM Limited Edition Thermochill EC-6 Clear 1000ml + Mayhems Dye Other Components: Aquacomputer USB Poweradjust 2 Pump Controller : Ultra 2x Lamptron Fan-Atic: 5-port 7x 120mm Enermax Magma (Green) 3x 120mm Scythe Kaze Jyuni Slip Stream 120mm Fan 1900 RPM How Cosmos S looks everyone know so I will skip showing it and start from naked pictures of case: Hole for 240 radiator on bottom: Rivets removed, case in pieces, many pieces ready to powder coat (black matt): Visit in powder coat workshop: couple minutes in furnace: and we have it: Putting case back together: Link to comment Share on other sites More sharing options...
mac1as Posted May 14, 2011 Author Share Posted May 14, 2011 OK time to move on, fan mode: Under UV light: Few small case moddifications: Here You can see pump mod: And some sleeving: Sleeving could be better. Cable menegment mode: My hands was bit shaking and its not like it should be, but it not so bad. Switch for UV Cathodes: Block for GeForce 9600GT to PhysX: and after nickle plating: Mobo I/O Backplate & GFX slots after powder coating: I installed blocks for GPUs, MOBO & MEM: New home for HDDs: I had to do 4 extra holes, to fit it to 5.25 bays: Now fits perfect: Some cable menagment on back tray: Mobo armed and ready to fight: Covers for Lamptrons ready, some photos: And DVD cover: Nearly finish: Cathodes on: Side cover for 360 top radiator: Original holes for cable menagment in case covered by UV grenn plexy: UV Cathodes to glow UV green plexy: Plexy under UV: Final version: Thank You for watching, hope You like it. Link to comment Share on other sites More sharing options...
PaPang Posted May 21, 2011 Share Posted May 21, 2011 Very clean and stately, and great choice of WCing components. The toggle switches are cool retro-looking on the face cover and green=acid, ok! Where is the powder coater at? His sign seems to be in English but his specialty appears not be small things like computer parts, there are dimpled parts but they are hardly visible anyways. Most might not see those spots. All the rest is close to perfect and you should be proud of the total product. Congratz! You might want to cut down a bit on the hd (which are quite well taken) pics which slow down viewing, my finger aches from scrolling, hehe. Cheers and Saludos Link to comment Share on other sites More sharing options...
