MonsterMawd Posted April 10, 2013 Share Posted April 10, 2013 The goal is hiding all of the tubing out of sight. Andrew in the workshop, he revised the connectors a bit and started routing the lines and tubing for the 480 EK radiator on top. This radiator has it's own EK Res on top, the other EK Res will connect to the front 480 for the quad 680GTXs. I recorded his progress for Part 3 of the videos highlighting his build, that will be posted HERE. Notice there is no cable holes in the MB tray for the ASUS Rampage IV, the lutro0 individually sleeved cables will curl and tuck under the MB. The Typhoon fans were painted to match the red on the exterior of the case. Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 15, 2013 Share Posted April 15, 2013 We're currently working on the front intake shroud design, and will share update soon! Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 20, 2013 Share Posted April 20, 2013 I sent our files for the four water blocks to another shop for Quote, I don't know if you heard recent Mod Zoo Podcast, but I mentioned in Opening, that last quote we got for four 680 GTX Classified water block assemblies to be made, was $5,500...Higher than we expected, but Mnpctech can't make the blocks, since their machines are tied to retail part commitments for this year.... So, as it stands, if this other shop's Quote is too much, Andrew is considering selling off his four 680 GTX classifieds for $550 apiece, shipped....He will purchase different video cards and use retail blocks, which would most likely be from EK. Link to comment Share on other sites More sharing options...
MonsterMawd Posted May 1, 2013 Share Posted May 1, 2013 Andrew and I have been busy, but haven't forgotten about sharing updates. We've got gap between production runs coming up and Cheaps offered to make the acrylic covers, so looks like we'll be back on track soon! crossing fingers and Roboduck offered his help in rendering the front intake shroud for the Cosmos II. Link to comment Share on other sites More sharing options...
MonsterMawd Posted May 7, 2013 Share Posted May 7, 2013 Here is what the Clear side panel looks like installed on the Cosmos II. It's cnc machined from .5" thick Chemcast Cast Acrylic with two 120mm fan holes with fastener holes for your own fan grills. FrozenCPU is offering Cosmos II Clear Side Panel that was made by Mnpctech Link to comment Share on other sites More sharing options...
MonsterMawd Posted May 24, 2013 Share Posted May 24, 2013 We're updating the video cards to 780s, and sold two of the 680s yesterday, so only two more to go! Thanks everyone, for yr patience! Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 6, 2013 Share Posted June 6, 2013 Milling the front 480 radiator grill bezel from 1.5" thick block of 6061 billet. The backside has been hollowed out, to save weight. the design was inspired by jet engine intakes Link to comment Share on other sites More sharing options...
MonsterMawd Posted June 22, 2013 Share Posted June 22, 2013 progress on the new bezel for CM II, this will shroud the front 480 radiator, it's made from 1.5" thick block of 6061 billet. The backside has been hollowed out, to save weight. the design was inspired by jet engine intakes Link to comment Share on other sites More sharing options...
MonsterMawd Posted July 3, 2013 Share Posted July 3, 2013 Andrew was able to get back into the shop, so we can make more headway on his build. We recorded footage for Part 4 of the "Rebel A" highlight videos we've been sharing on YouTube. I'll post some screen captures this week. Here is the details on the cover created for the lower section of the Cosmos II chassis. It has two 120mm fan holes. The side air vents were taken from an old chassis I had. The fans are Scythe Gentle Typhoon 120mm Case Fan- 1,850 rpm, 28 dba, 58.3 cfm with painted blades. The cover fastens in place with Thumbscrews Here is what the lower cover and Clear side panel looks like installed on the Cosmos II. It's cnc machined from .5" thick Chemcast Cast Acrylic with two 120mm fan holes with fastener holes for your own fan grills. FrozenCPU is offering Cosmos II Clear Side Panels, with and without fan holes Link to comment Share on other sites More sharing options...
MonsterMawd Posted July 6, 2013 Share Posted July 6, 2013 I think it would be cool to leave the center portions of the grill intakes bare aluminum... After taping them off, a base coat of self-etching primer was applied before the Grey color coat. That was later topped with FLAT clear coat Link to comment Share on other sites More sharing options...
