Arcis Modz Posted March 8, 2015 Author Share Posted March 8, 2015 hey guys.. its been a while since my last update. so now, all side are now assembled and they are now attached to each other. just cleaned my current pc setup since i will need the hardware for some test fits and measurement. but da*n... its only been 3 months and that dust.... and now some test fits.. doing some bending for the shroud. accidentally dropped it. *sigh* need to do some rework... thanks for viewing. Link to comment Share on other sites More sharing options...
Arcis Modz Posted March 11, 2015 Author Share Posted March 11, 2015 hi guys. cut the I/O shield and finish the mobo tray. also, playing with some led strip for testing. lights off. lights on. Link to comment Share on other sites More sharing options...
Alucard Posted March 11, 2015 Share Posted March 11, 2015 Grt work so far Andrew... (y) Link to comment Share on other sites More sharing options...
Arcis Modz Posted March 12, 2015 Author Share Posted March 12, 2015 Grt work so far Andrew... (y) thanks bro.. got a chance to borrow a tripod from a friend. so i updated the hardware/box photo section of the first post. my photo studio. hahahahahaha. Link to comment Share on other sites More sharing options...
Arcis Modz Posted March 14, 2015 Author Share Posted March 14, 2015 hey guys... some updates for this build. just finished the psu shroud and the cutout for the gpu bracket locking system for my gpu... no need to screw...so far gpu is tightly secured.... hope it works as it should be. if not.. plan b.. Link to comment Share on other sites More sharing options...
Arcis Modz Posted March 16, 2015 Author Share Posted March 16, 2015 got home early from work so i decided to play with mayhems coolant. that green. ay lab et. Link to comment Share on other sites More sharing options...
Buckroger Posted March 18, 2015 Share Posted March 18, 2015 Wait!! are u choro_kairo?? u looks very familiar lel... btw, nice build bro!! eager to see the outcome . Link to comment Share on other sites More sharing options...
Buckroger Posted March 18, 2015 Share Posted March 18, 2015 double post, internet connection problem Link to comment Share on other sites More sharing options...
Arcis Modz Posted March 19, 2015 Author Share Posted March 19, 2015 hahaha... yes bro.. chrono_kairo of lyn. real name is andrew lee. thanks btw. Link to comment Share on other sites More sharing options...
Buckroger Posted March 19, 2015 Share Posted March 19, 2015 Small worlds.. Im buckroger of lyn.. Good luck bro!!! Link to comment Share on other sites More sharing options...
