Rakazone21 Posted May 1, 2017 Author Share Posted May 1, 2017 Before I do the washing board, first remove the cmos battery. Then remove the stickers Sandpaper parts that are rusty and dull Chipset legs have started to mold And air ducts that have begun to dull Brush parts per section so that the dirt will come swept brush After finished cleaning and rinsed with clean water, then I do spraying with air compressor, then assisted drying using hairdryer, drying under the hot sun until benar2 dry, then enter again to dry box so that water lost from surface and interrupted chipset. Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 3, 2017 Author Share Posted May 3, 2017 hello friend.. yesterday i'm do something for finishing.. such as polish the main frame, spray for finishing, and clear it. here it's Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 3, 2017 Author Share Posted May 3, 2017 Make foot the case.... Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 3, 2017 Author Share Posted May 3, 2017 Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 3, 2017 Author Share Posted May 3, 2017 Special Thankyou to the cooler master who has organized event case mod 2017. hopefully in the 25th anniversary this is a fortune and progress in the coming era, plus the existence of mod event like this .. I think can accommodate creativity and distribution of hobby anthusiast pc like me and Friends of other modder. Thank's to My parent's, brother, sister and my friends Specifications My Pc Rig: CPU : Amd Phenom x6 1055T Motherboard : Asus Rog Crosshair IV Formula VGA : Palit Geforce GTX 275 series RAM : Corsair Vengeance Pro Series 16GB SSD : Pioneer SSD 120 Gb Case : CoolerMaster CM Stacker Black PSU : Corsair Hx1000 Watt. Cooling : Cooler Master X6 Fan : Enermax Tb Appolish 12cm 1pcs, Da Orkaan 12cm 4pcs, Cooler master 12cm 1pcs, Thermaltake 8cm 1pcs, Corsair Ram cooler 1pcs Cable sleeving : Mod custom Pict's Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 4, 2017 Author Share Posted May 4, 2017 Led Thermaltake Text Cooler Master, 25Th Annivessary, Casemod 2107, Rakazone21 Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 4, 2017 Author Share Posted May 4, 2017 Link to comment Share on other sites More sharing options...
Rakazone21 Posted May 4, 2017 Author Share Posted May 4, 2017 Alhamdullilah.. Link to comment Share on other sites More sharing options...
