WiP PC Modz Posted August 27, 2019 Author Share Posted August 27, 2019 BODY & ARMS (FILLER) I also applied body filler to reinforce the arms and the body. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted August 27, 2019 Author Share Posted August 27, 2019 THE HEAD (ASSEMBLY) It's hard to make some round forms on a box so I used tie wire and mesh to make the head of the beargguy. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted August 27, 2019 Author Share Posted August 27, 2019 THE HEAD (FILLER) I ran out of epoxy resin so in the head part, I used plain body filler. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted August 27, 2019 Author Share Posted August 27, 2019 THE HEAD (CUTTING) I cut the head to half,and added some holes for vents and window.Also i've added a hump on the face part Link to comment Share on other sites More sharing options...
WiP PC Modz Posted August 27, 2019 Author Share Posted August 27, 2019 SANDING The hardest and dirtiest part of the work,sanding!! Link to comment Share on other sites More sharing options...
WiP PC Modz Posted August 27, 2019 Author Share Posted August 27, 2019 ARMS (ASSEMBLY) Using some old plastic container hanging around,I managed to make them as the mount of the arms to the frame of the beargguy. Test fitted them and it works Link to comment Share on other sites More sharing options...
WiP PC Modz Posted August 27, 2019 Author Share Posted August 27, 2019 HANDS (CLAWS) In here I used scraps of PETG Tubes for the claws. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 3, 2019 Author Share Posted September 3, 2019 THE HEAD (ADJUSTMENT & BRACKET INSTALLATION) I have added fillers on the nose and mouth part. Plus I installed the brackets where the head will be held. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 3, 2019 Author Share Posted September 3, 2019 PRIMER & PAINTING I have started the painting job,currently on-going Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 3, 2019 Author Share Posted September 3, 2019 HEAD (INTERNAL PART) Added aluminum foil on the inside to dissipate heat quickly inside the case. Then I cut some mesh for the eyes part. Link to comment Share on other sites More sharing options...
