WiP PC Modz Posted September 8, 2019 Author Share Posted September 8, 2019 AIO WATERCOOLING MOD I managed to rip-off the Cooler Master MasterLiquid ML240L RGB, and I plan to add the PSU and a reservoir to the loop. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 8, 2019 Author Share Posted September 8, 2019 GPU REPAINTING In here I have repainted the MSI Gaming X RX570 to match the color scheme of my build. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 8, 2019 Author Share Posted September 8, 2019 HARDWARE INSTALLATION Test fitted and installed the hardwares to be used in this build.. Special Thanks to the sponsors of this build: Cooler Master AMD MSI FSP Li-Heat Industry Team Group-T-Force Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 14, 2019 Author Share Posted September 14, 2019 PSU CABLE SLEEVING I used pink,gray and black combination of sleeves on the FSP PTM+ 850w power supply to match the color scheme of my build. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 14, 2019 Author Share Posted September 14, 2019 AIO ASSEMBLY In here I used 3/8 5/8 soft tubes connecting to the AIO block,radiator,reservoir and PSU. The pump of this MASTERLIQIUD ML240L RGB is so strong,it easily manages to watercool this Beargguy project. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 14, 2019 Author Share Posted September 14, 2019 COVERS AND DETAILING Assembly of front cover,and detailing of the Beargguy. For the cover, I want to expose the power supply inside so I made a "battle damaged hole" and planning to add some weathered painting theme on it. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 26, 2019 Author Share Posted September 26, 2019 WINGS! I added some wings for the rear part of the build.. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 26, 2019 Author Share Posted September 26, 2019 Weathering and Final touches Bound to the last part of this worklog,I added some touch of "battle scars" and weathering to make it look realistic I used paint brush and sponge to apply the paint.. Link to comment Share on other sites More sharing options...
WiP PC Modz Posted September 26, 2019 Author Share Posted September 26, 2019 BOOT UP! Now we have to test the build before taking some final shots Link to comment Share on other sites More sharing options...
WiP PC Modz Posted October 3, 2019 Author Share Posted October 3, 2019 THE FINAL CHAPTER And so the mod has come to an end, I present you this project: Beargguy P (Pretty) The concept of the mod is based on the famous Gunpla model kits produced by Bandai, Beargguy lineups. I found it cute and attractive,specially when they are in battle mode Added some sort of weathering design,scars and destroyed parts to make it look like old, battle damaged and realistic. The components are installed in the head part, the face tilts and the back of the head slides up to gain access on the motherboard.Power supply is affixed on the body. For the cooling, I customized the Cooler Master MASTERLIQUID ML240L, added a reservoir and extended the tubes. So there she goes. Hope you loved the build! Special thanks to my sponsors: COOLER MASTER AMD MSI FSP TEAM GROUP Li-Heat Industry Co. Ltd Time lapse build available here: Link to comment Share on other sites More sharing options...
