daguar Posted September 12, 2019 Author Share Posted September 12, 2019 I even forgot to document the process of making a 70mm fan grill. The painting process has been done, even though I haven't yet smoothed every piece I have to repeat the process to make it look smoother. The fan intake that I used was taken from AMD cpu stock cooling fan some revisions must be made to the construction of the support, because there is a difference in the heavy fulcrum between the front and back of the casing. note: in the background there is a sliding window for the side panel that is too focused on it so I forgot to document it Link to comment Share on other sites More sharing options...
Haris Budiriandi Posted September 13, 2019 Share Posted September 13, 2019 Keep up the good work kaka.... Minta ijin copas fotonya ya kaka......lop yu deh... hahahha Link to comment Share on other sites More sharing options...
daguar Posted September 13, 2019 Author Share Posted September 13, 2019 8 hours ago, Haris Budiriandi said: Keep up the good work kaka.... Minta ijin copas fotonya ya kaka......lop yu deh... hahahha dadaekanan copas ih. foto barutut kitu Link to comment Share on other sites More sharing options...
daguar Posted September 16, 2019 Author Share Posted September 16, 2019 a lot of work is not documented in detail. Maybe because I was too busy doing. I attach work whose details are not documented Link to comment Share on other sites More sharing options...
daguar Posted September 16, 2019 Author Share Posted September 16, 2019 Work is almost done. Running test has been done. One of them is adjusting the lighting and color of the lights that will be used. Thanks God, everything went smoothly. Link to comment Share on other sites More sharing options...
daguar Posted September 16, 2019 Author Share Posted September 16, 2019 body coloring with primer and top coat paint. Do not forget to include weathering and battle damage effects. the finishing process is still not done until now Link to comment Share on other sites More sharing options...
Haris Budiriandi Posted September 17, 2019 Share Posted September 17, 2019 On 9/13/2019 at 8:22 PM, daguar said: dadaekanan copas ih. foto barutut kitu bodo amat dengan foto..masih bisa ditacap... yg penting mah hasil akhir Link to comment Share on other sites More sharing options...
daguar Posted September 17, 2019 Author Share Posted September 17, 2019 2 hours ago, Haris Budiriandi said: bodo amat dengan foto..masih bisa ditacap... yg penting mah hasil akhir Link to comment Share on other sites More sharing options...
daguar Posted September 17, 2019 Author Share Posted September 17, 2019 do the panel cover with the main body using DIY hinges Link to comment Share on other sites More sharing options...
daguar Posted September 17, 2019 Author Share Posted September 17, 2019 provide mild rust and weathering effects. Link to comment Share on other sites More sharing options...
