random2k4 Posted October 11, 2019 Author Share Posted October 11, 2019 For the LED panels I still needed to build a small shroud. I simply cut some acrylic into shape and painted in in the same color as the panels itself. They were put into place just by some double sided tape. If you know the movie, you know that the WOPR has some lables all around. At first, I wanted to make a stencil and spray it on, but watching the movie again, made me realize, they just used some vinyl to make the lables. So, I went over to my vinyl cutter and made my own. And attached them already. To start the computer and LEDs later, I needed some buttons. They should not be visible from the outside, So I put them behind the cover at the front. Programming the LEDs was now the last step. Its really a bunch of code. Here you can see a picture from the work in progress, but it already shows the effect pretty good. Link to comment Share on other sites More sharing options...
random2k4 Posted October 11, 2019 Author Share Posted October 11, 2019 And ofc some final pictures Link to comment Share on other sites More sharing options...
random2k4 Posted October 11, 2019 Author Share Posted October 11, 2019 And also a video showing the making-of and the LEDs in motion.: Link to comment Share on other sites More sharing options...
random2k4 Posted October 11, 2019 Author Share Posted October 11, 2019 Just wanted to add one more picture, so you can see the scale a little better. Link to comment Share on other sites More sharing options...
