Maurycio Gyovanni Posted October 21, 2020 Share Posted October 21, 2020 INTRODUCTION “OZOB” is the name of the current project for 2020. Loved by the Brazilian nerds, Ozob was presented in 2013 for the podcast series called “Cyberpunk RPG” is a replicant bald, red-haired, albino mercenary with a red grenade in the place of his nose, a dystopian, mocking clown. In addition to the podcast that has been a success for more than 14 years of existence, the character has already turned several products such as t-shirts, collector's items, books and will be present in the game Cyberpunk 2077 to the delight of fans in Brazil. A theme owned by Deive Pazos, co-owner of the Portal “Jovem Nerd”, this website has expressive access numbers above 40 million pageviews monthly, apart from that it has the best known podcast in Brazil accounts for more than 1 million downloads each edition of “nerdcast” and its youtube channel easily exceeds 400 thousand views per episode. PROJECT DESIGN CONCEPT The idea of the project is to create the most fantastic painting in the world with details in flawless airbrushing and very inspired by the book cover of the same theme. HARDWARE & SPONSORS Thanks to Coolermaster, AMD, Aorus, Team Group, Gigabyte and Alpha Acrilico for the support. Specifications: CASE: COOLERMASTER C700M MB: Gigabyte B550 VISION D VGA: AORUS RTX 2070 XtremeCPU: Ryzen R5 3600XRAM: Team Group Nighthawk DDR4 RGB 8GB x4 SSD: Team Group Delta MAX 250GBSSD M2: WD_Black SN750 M.2 250GB x2PSU: COOLERMASTER V Gold SFX 850wFAN: COOLERMASTER Masterfan SF120R ARGBAIO: COOLERMASTER Master Liquid ML240RS RGB KEYBOARD: COOLERMASTER SK650MOUSE: COOLERMASTER MM830 PAD: COOLERMASTER MP750 XL HEADSET: COOLERMASTER MH752 3 Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 20, 2021 Author Share Posted January 20, 2021 (edited) I hope I have enough time to make the publications, firstly some of the pieces used. My C700P and C700M of this project. C700M Gigabyte B550 Vision D Other Acessories I love this keyboard My new HS Aorus RTX 2070 Xtreme 10 fans 120mm Wc used Edited January 20, 2021 by Maurycio Gyovanni Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 21, 2021 Author Share Posted January 21, 2021 (edited) Disassembling the case Start of painting I decided to modify the front air intake And now one of the coolest parts: Airbrushing. The art chosen for the theme is based on the cover of the book that tells a little about the life of the character Ozob. Step by Step Edited January 21, 2021 by Maurycio Gyovanni text insertion Link to comment Share on other sites More sharing options...
C0571NH4 Posted January 21, 2021 Share Posted January 21, 2021 Awesome mod. More pics of details please. 1 Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 22, 2021 Author Share Posted January 22, 2021 (edited) continuing ... Edited January 22, 2021 by Maurycio Gyovanni 1 Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 23, 2021 Author Share Posted January 23, 2021 (edited) I had the idea of replacing the original logo of my watertcooler I made the measurements an accessory that the project's theme character wears on his nose: a grenade It was cut in half and after painted Pinned in place Another idea I had was to place the watercooler radiator next to the motherboard I made the measurements And a structure was made in metal that could fix the radiator, allowing it to push and pull the ventilation system Painting with logo included Tests And it worked! Edited January 23, 2021 by Maurycio Gyovanni 1 Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 24, 2021 Author Share Posted January 24, 2021 (edited) More paint Front 4 120mm fans in front, original C700P only space for 3 120mm fans laser markings and parts are glued one by one manually tests And I decided to put the theme character on all the fans Here's the cover idea and ready first in wood later in acrylic and of course my partners are highlighted =D Edited January 24, 2021 by Maurycio Gyovanni Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 25, 2021 Author Share Posted January 25, 2021 (edited) I had the idea to use the inside of the Ozob book cover to create the envelope Another idea was to create the first vertical video card cover: Here is it another details radiator cover "Jovem Nerd" eastereggs and "RGB BABACA" Edited January 25, 2021 by Maurycio Gyovanni Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 27, 2021 Author Share Posted January 27, 2021 (edited) Returning to painting, it was based on the cover art of the book as I said at the beginning of the publications, but here is the image of the Ozob in the game Cyberpunk 2077 The art continues... the cigar smoke And of course: the Coolermaster Brand couldn't be missing! Edited January 27, 2021 by Maurycio Gyovanni Link to comment Share on other sites More sharing options...
Maurycio Gyovanni Posted January 30, 2021 Author Share Posted January 30, 2021 Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
