Mike Dulay Posted December 20, 2022 Share Posted December 20, 2022 Good day! As part of my build for the scratch mod category, I've included some "accessories". There some extra wood pallet left over from the build and I decided to use it. First I made a laser cut-out of the design I will be using as template in cutting and shaping the wood. Next, with the use of a router, I made a canal/channel in the wood... Next I shaped the wood using a bandsaw... ...with an angle grinder... ...and sandpaper... .... And now we have a cellphone holder/stand...(I know it's not a cm product but still Still using recycled wood, I made a keyboard wrist rest for the Cooler Master Ck350 Mechanical keyboard... Same procedure as above....cut, shape, sand.... Finally, add wood stain (mahogany) ...then wipe ...let dry... ...then spray with sanding sealant... The first accessory made was a headset holder for the Cooler Master MH752 Gaming Headset. It is made of wood and to attach it to any metal part of the case, a neodymium magnet was placed on the other side. Link to comment Share on other sites More sharing options...
Mike Dulay Posted December 20, 2022 Author Share Posted December 20, 2022 (edited) ....And here are the items made... they are not complete mods but I just wanted to share what was made with the left over wood from the project. Wood working skills still needs a lot of improvement. Edited December 20, 2022 by Mike Dulay 1 Link to comment Share on other sites More sharing options...
Mike Dulay Posted December 23, 2022 Author Share Posted December 23, 2022 PHOTODUMP II Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
