PaPang Posted July 22, 2009 Share Posted July 22, 2009 Wow, nothing can beat a laser or water cut for sure! By the way, are you entering the 2009, Mod Contest? If you are, you just have to add "2009 Modding Contest Entry" or of the sort in the title to let us know. Cheers Link to comment Share on other sites More sharing options...
tantric Posted August 20, 2009 Author Share Posted August 20, 2009 They certainly did a great job with the acrylic & wouldn't mind somewhere capable of doing that in these parts.(I'm at a beach resort area, not known for it's mix of powdercoaters & laser cutting companies ) used to work at an advertising company, you'd be surprised that the tools/materials used in the business are very similar from what we use in modding. some more updates. the custom top used on the D5 top looks kinda plain and boring and it didn't really match the theme of the case. so decided to spice things up a bit. started by dis assembling the pump. then we proceeded to murdering the top. lol! i'm using a 7/16" drill bit to enlarge the original hole. then a G1/4 pipe tap. Link to comment Share on other sites More sharing options...
tantric Posted August 20, 2009 Author Share Posted August 20, 2009 then i used some left over lian-li side panels. and cut it to size using a hand nibbler. a quick spray of candy red spraypaint. and heres the end result. Link to comment Share on other sites More sharing options...
zer09 Posted August 21, 2009 Share Posted August 21, 2009 great accents! Link to comment Share on other sites More sharing options...
Skateboxx Posted August 21, 2009 Share Posted August 21, 2009 nice one sir tantric! Link to comment Share on other sites More sharing options...
tantric Posted August 23, 2009 Author Share Posted August 23, 2009 thanks! Link to comment Share on other sites More sharing options...
kitaswandi Posted August 23, 2009 Share Posted August 23, 2009 nice one there master tantric!! kitaswandi salutes the master :salute: Link to comment Share on other sites More sharing options...
tantric Posted August 23, 2009 Author Share Posted August 23, 2009 thanks to all! Link to comment Share on other sites More sharing options...
michaelv Posted August 24, 2009 Share Posted August 24, 2009 Great work master Tantric! Link to comment Share on other sites More sharing options...
blackmoly Posted August 24, 2009 Share Posted August 24, 2009 very nice sir tantric Link to comment Share on other sites More sharing options...
