Jump to content
Lament Configuration By Tortured Soul - Finished -
Tortured_soul
  • Replies 38
  • Created
  • Last Reply
Hardware:
Motherboard: Asus M2N68-AM SE2:
Ram ddr2 markvision:
Vcard: ASUS EAH5670/DI/1GD5 Radeon HD 5670 (Redwood) 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card:
Processor:
AMD ATHLON II X2 250, 3000MHz
COOLER MASTER PRODUCT:
cooler: HYPER - N620
Hyper vs stock
AND FAN 120mm
Hard disk: Seagate 160 gigas
Keyboard wireless
And mouse wireless
Link to comment
hello friends // hola amigos,
This project is inspired by the hellraiser cube called "Lament Configuration".//este proyecto esta inspirado en el cubo de hellraiser llamado "lament configuration".
This is a work that is started of zero, and the main materials are aluminum and acrylic.//Es un trabajo comenzando de cero, y los materiales principales serán, aluminio y acrílico.
angle of aluminum: 8/4 x 1/8
acrylic: white 3mm x 32cm and black 2mm x 32 cm
L + screw
start drawing // inicio del dibujo
beginning of the draft // inicio del calado
filing // limado
and video:
More progress soon...
Link to comment
Hola Tortured!
Good to see as well as surprised! Hope your project does well with this ferocious competition! I would have my doubts on how one of my mods would stand up with so many greats here and more coming everyday.
This means you really have to stretch your efforts to the max and it will be a testimony your modding excellence and an experience to not forget so easily. As always, the best of luck and I will be following your project to the end.
Cheers and Saludos
Link to comment
  • Create New...
Important Information
