Pobbrett Posted March 11, 2011 Share Posted March 11, 2011 only other thing i can think of is some sort of mineral oil tank Link to comment Share on other sites More sharing options...
FrenkieNL Posted March 11, 2011 Share Posted March 11, 2011 Choloform Link to comment Share on other sites More sharing options...
DaveM Posted March 12, 2011 Author Share Posted March 12, 2011 Ok so I am finished with this little part of the build. Now to reveil the par with the glass... Its called optical bonding. I used to work for a company that opticly bonded LCD panels. So i figured I would toss that in the mix with this build... Here it is. When you put a certain type of glass with a coating on it and then add silicone layer between the glass and LCD module, then you upscale the contrast ratio making the panel easier to see by the human eye, so this is what I have done to this monitor… I urge anyone that is looking at this to not attempt to perform this since I have been trained in how to do this and if done incorrectly… Well you will mess up the monitor that you are attempting to bond. I hope you are enjoying this build. Link to comment Share on other sites More sharing options...
DaveM Posted March 20, 2011 Author Share Posted March 20, 2011 Slight delay Mod progress the ribbon wires on the back side of the LCD had started to break and i had to replace the entire wiring of the LCD module/panel to the controler board inside.... GRRRRRRRR 2 hours later got it done will have new photos up tonight of some of the progress on wiring and soldering and a few of the case itself as it moves along today. Thanks for looking. any comments welcome Link to comment Share on other sites More sharing options...
DaveM Posted March 22, 2011 Author Share Posted March 22, 2011 The Floating Tower... Link to comment Share on other sites More sharing options...
DaveM Posted March 23, 2011 Author Share Posted March 23, 2011 More photo updates for you to check out... Link to comment Share on other sites More sharing options...
DaveM Posted March 23, 2011 Author Share Posted March 23, 2011 Hidden ROM tray... HEY I LOST MY LIGHTER... Any help here Link to comment Share on other sites More sharing options...
ArgOs Posted March 24, 2011 Share Posted March 24, 2011 I'm going to continue watching the progress of this project, I think that will have many lights. Link to comment Share on other sites More sharing options...
DaveM Posted March 24, 2011 Author Share Posted March 24, 2011 I'm going to continue watching the progress of this project, I think that will have many lights. Yes Argos Many lights Link to comment Share on other sites More sharing options...
DaveM Posted March 25, 2011 Author Share Posted March 25, 2011 So what can one do with a pair of Windsheild wiper arms LOL they wont clean a windsheild liek this... HHHMMM wait I got an idea... messure here.. Hey you might think I put the picture up twice, nope just doing what my friend bob the builder says... Messure twice and cut/drill once. Yeh I know bob would have told me not to drill on a pool table also. hmm floating hard dives, might be cool looking. Oh and I have big plans for these little wonder lights... Link to comment Share on other sites More sharing options...
