Rikuntyudady Posted April 27, 2011 Share Posted April 27, 2011 This is the most favorite PC case for me. It made it to customizing that did not destroy as original a design as possible. I'm sorry when wrong because I'm Japanese, and it is not good at English. It ditches it to the reception desk part with an acrylic cutter. "EL Wire" is installed according to the ditch. The power supply is supplied from fan controller with fan connector. It was lit. It emits light uniformly. The mesh part in the reception desk is painted on the orange. "Knight flasher" is introduced into 5.25-inch bay. This LED can choose the illumination pattern of the number of patterns including the reciprocation work right and left. The mesh part of the bay cover is detached, and the acrylic piece of the smoke-color is installed. The film label that prints the logo on an acrylic piece of the transparency is put on the other side. The logo comes to the surface when shone on from the other side with LED. The I/O panel part in the reception desk is customised. Tape LED and the acrylic piece are used also for the other side here. It becomes it like this when lighting. The power supply of fan controller who is controlling the power supply of the illumination is turned on and can be turned off with this touch switch. It lights by only the illumination whose fan controller's switch is turning on touching this switch. The logo in the lock part in 5.25-inch bay is painted. When the emery paper is put after the whole is painted in white, paints remain only in the logo part. The base in the lock part is painted on the orange. The HDD mounter is similarly processed. It installed it. The PCI cover is painted on the orange. The side panel is made with the acrylic bord. The acrylic bord is stopped by installing the board of the metal in the center, and using the hinge for here. It is possible to open by this like the door. LED of the memory cooler is exchanged, and the main body is painted. The black one is sold now. State of lighting. The acrylic piece that prints the film label is installed in the hole for wiring in the upper part of the mother board. Customizing of reception desk fan cover. Because the side panel was made an acrylic bord, the back side of 5.25-inch bay is concealed. It used "3M DI-NOC Carbon" It's done. Thanks. YouTube ã€Extra】 Tape LED is installed along an acrylic window of the side panel of normality. When the label that prints the logo is pasted or the character is written with a fluorescent marker … It is possible to make a hand-written character come to the surface. Link to comment Share on other sites More sharing options...
PaPang Posted May 24, 2011 Share Posted May 24, 2011 Ok! One of the few mods I have seen from Japan, kudos for registering & showing your wares! Very respectable build with a lot of fine details, and yes, the HAF is a fine case, I have one too but is still boxed because I am still figuring out what to do with it (going on 2 years so I admit I still don't know what to do, hehe). I lean more to scratch builds but I definitely have to do something with mine. Best of Luck! Cheers and Saludos Link to comment Share on other sites More sharing options...
Rikuntyudady Posted May 25, 2011 Author Share Posted May 25, 2011 Ok! One of the few mods I have seen from Japan, kudos for registering & showing your wares! Very respectable build with a lot of fine details, and yes, the HAF is a fine case, I have one too but is still boxed because I am still figuring out what to do with it (going on 2 years so I admit I still don't know what to do, hehe). I lean more to scratch builds but I definitely have to do something with mine. Best of Luck! Cheers and Saludos Thank you for the comment. My having bought A becomes about two years ago. The next...I want to customise the side panel,but no idea. My friend in Japan also is doing a wonderful customizing HAF932. Please see it;) http://www.techpowerup.com/gallery/2820.html Link to comment Share on other sites More sharing options...
masbuskado Posted May 25, 2011 Share Posted May 25, 2011 I really like the touch and details on the Cooler Master buttons! Link to comment Share on other sites More sharing options...
Rikuntyudady Posted May 29, 2011 Author Share Posted May 29, 2011 I really like the touch and details on the Cooler Master buttons! Thank you for your comments. Link to comment Share on other sites More sharing options...
FrenkieNL Posted June 2, 2011 Share Posted June 2, 2011 Congratulations Link to comment Share on other sites More sharing options...
KITSON CHAN Posted June 2, 2011 Share Posted June 2, 2011 Congratulations! Link to comment Share on other sites More sharing options...
Rikuntyudady Posted June 3, 2011 Author Share Posted June 3, 2011 Congratulations Thank you!! I'm very very very grad. Link to comment Share on other sites More sharing options...
Rikuntyudady Posted June 3, 2011 Author Share Posted June 3, 2011 Congratulations! Thank you !! I am very glad to be exhibited to COMPUTEX. Link to comment Share on other sites More sharing options...
PaPang Posted June 3, 2011 Share Posted June 3, 2011 Hmmmmm, the top or bottom one? Grading according to CM standards: Top) 71/100 Bottom) 92/100 The winner: MY GEAR by rikuntyudady. Congrats and thanks for the link! Cheers and Saludos Link to comment Share on other sites More sharing options...
