Jump to content
[CoolerMod] TxMod - Finished
Gusts
Hello guys, this is my second participation in a Cooler Master Contest and this time I'll make a modification in a cooler.
The idea is make a modification in a modest cooler, in this case I'll use the Cooler Master Hyper TX3 :
It is a very simple cooler :cry: , but I belive is possible to transform in a amazing cooler :twisted: . For this I'll use a recycle materials that I have in home, for example:
- Acrylic Scraps
- Original fan grills from Cooler Master CM690 :wink:
I hope you enjoy the project development.
Let's go !?
Cheers,
Gusts. :wave:
Link to comment
  • Replies 29
  • Created
  • Last Reply
Hello everybody I made the project on the sketchup, and the ideia is make a removable structure in the cooler using the acrylic and the fan grill. Let`s see: :shock:
So I drew on the Corel Draw...
What are you think about it ? :roll:
Regards,
Gusts.
Link to comment
Good sketch on how you idea for the cooler mod may or may not look. Sometimes less is more & I think it does look good, only suggestion I'd make is maybe incorporate a fan guard from the main body around the cooler. This would help with the air flow I reckon as, as it is it may not do too much on the performance of the cooler itself?
Link to comment
Thanks frozensnail ! You are right about the air flow. I did some test here and without the fan guard I lost a lot of air flow. So I am thinking about a solution for this using the original fan, but I won't like to make a unique body. Maybe I'll use another way to fix de fan :thumbright:
Link to comment
frozensnail I though in a simple solution, but it will integrate the original fan with the main body :D . In the future posts I'll show the 2.0 version :wink:
In that last weekend I cut the pieces:
Making some test:
Cut cut cut... :bounce:
I still need to finish the pieces :happy8:
Regards,
Gusts.
Link to comment
Thanks Mooz! :D
My idea is make the thinks every weekend and finish it as soon as possible.
So, let's go to update... :P
In the first step I cut the grills
After I cut the acrylic pieces I improved some parts
For join every pieces temporarily I used an acrylic glue and tapes :wink:
Testing...
Testing again...
I began sanding the piece to remove and see the irregular points
Like this:
I used a plastic mass to solve this problem
I needed to adjust the grill size
Now is OK :D
Testing again and again...
I'll need to regulate the mass before paint
I hope to paint in the next weekend.
Regards,
Gusts.
Link to comment
  • 2 weeks later...
Hello guys, this weekend I made the first step of paint.
I began preparing the pieces to paint
Painting...
Sanding the plastic mass at the main part
And the first paint
Correcting the imperfections and sanding again...
As was already Saturday night I decided paint on Sunday and make other important piece
:D
On sunny Sunday I painted the piece
Fixing at the main body
Isolating to paint the main part
And painting again...
I did some tests with the painted pieces
As you can see I did some tests with the version 1.0, but I thought in a good solution to fix the fan at the main part.
In the next update I'll show you :wink:
Regards,
Gusts :cheers:
Link to comment
  • Create New...
Important Information
