kartner Posted September 12, 2012 Author Share Posted September 12, 2012 Done with the LCD frame holder used double adhesive tape on the LCD board so it doesnt move around. added back painted acrylic on the sides, and removable Lenses. Spacers were made to keep lenses in place and to keep distance requirements exact this is mounted by double adhesive for easy maintenance This frame will prevent excess light from coming out of the projector, alternatively i can be swapped with different translucent acrylic to allow a colored boarder to be visible (this will be a future experiment once it works) Perspective view: Final arrangement: Front Fresnel, colored Frame, LCD (not installed in this picture) and the back fresnel Link to comment Share on other sites More sharing options...
dropoyin Posted September 12, 2012 Share Posted September 12, 2012 looks great... Link to comment Share on other sites More sharing options...
kartner Posted September 15, 2012 Author Share Posted September 15, 2012 MY LED water block design... done with cutting.. it took a grueling 4Hours to cut this on the laser bed... due to engrave settings didn't expect it to be that long ... hahah attaching the water barbs.. used cloth so I don't damage/scratch the acrylic Back view Front water flows to the left and right and exits above, I've left a hole underneath the LED for wiring Link to comment Share on other sites More sharing options...
kartner Posted September 16, 2012 Author Share Posted September 16, 2012 My pump, will not be using the filter side I've tested for leaks and there were leaks all over the sides , thankfully I took this into consideration in the design, etched the perimeter for gasket/ sealant Ok, first thing I did to stop the leak was to tape everything up to put in the high temp sealant and manually cut where the sealant needs to be placed. I've also put in sealant at the front before placing in my LED light, dip your screws in in sealant also before using it on the LED its one of the problem areas where water comes out from Placed in all the wiring I need to Light the LED including the digital thermometer, After which I filled the hole with Sealant Link to comment Share on other sites More sharing options...
kartner Posted September 21, 2012 Author Share Posted September 21, 2012 ok been inactive for quite a while due to work... anyway, I've been studying how to make the face of the CPU, My material of choice is still acrylic plastic I've been trying to figure out how I could make pepakura work with corel and sketchup. So far Ive been able to cut a couple of trial parts, Finalizing the layout for cutting Link to comment Share on other sites More sharing options...
kartner Posted September 23, 2012 Author Share Posted September 23, 2012 unitology scripts I'll be etching inside the casing some work done on the font to make it look like it's hand written by the dying crew This will be a custom water block for the top of the Cooler master 212 and casing for the pump Link to comment Share on other sites More sharing options...
kartner Posted September 23, 2012 Author Share Posted September 23, 2012 Modding the cooler master hyper 212 removed the aluminum fins about 7 pcs and cut the top part of the copper heat pipes with a grinder drilling holes into the acrylic I laser cut ( got lazy measuring the exact location of the holes so I just drilled it Test fit the acrylic and everythings ok. Sealant will hold acrylic into place and will take care of any leaks Hyper 212 now has a water block will take more pics when This is polished up Link to comment Share on other sites More sharing options...
kartner Posted October 4, 2012 Author Share Posted October 4, 2012 Installed the Cooler master 212 hyper evo on my motherboard Used plastic cement (typically used in Gundam models) to polish up the acrylic parts I found it useful in sealing up small leaks aswell. Etch on top ( Cooler Master ) unitology font Link to comment Share on other sites More sharing options...
MooZ Posted October 4, 2012 Share Posted October 4, 2012 Any idea what it say? lol nice job dude!! Link to comment Share on other sites More sharing options...
kartner Posted October 4, 2012 Author Share Posted October 4, 2012 @ Mooz Thanks!! there's more coming up, just cant find the time to update... haha BTW That says Cooler (top) and Master ( bottom) Edited text For a Cooler Master LOGO Deadspace Style Link to comment Share on other sites More sharing options...
