IMCustoms Posted March 30, 2015 Author Share Posted March 30, 2015 Andddd plexi backplates are almost done (only holes for bolts to pass are left to drill) This is that 8mm thick backplate for motherboard, but the board is packed and I didn't really had time to place it on top So you will only get 2 pics with different exposures Link to comment Share on other sites More sharing options...
IMCustoms Posted April 1, 2015 Author Share Posted April 1, 2015 The desk is in his final place Currently everything is plugged into a laptop, but that will change soon! Link to comment Share on other sites More sharing options...
chitoz Posted April 2, 2015 Share Posted April 2, 2015 very nice keep it up sir ! Link to comment Share on other sites More sharing options...
IMCustoms Posted April 2, 2015 Author Share Posted April 2, 2015 Thanks christian dumdum, more to come soon! Link to comment Share on other sites More sharing options...
IMCustoms Posted April 4, 2015 Author Share Posted April 4, 2015 Sooo... I'm a perfectionist, and I wasn't really satisfied with a work I've done on that "main" board on which everything important will go.. So I decided to scrap it and make another one on a CNC machine and this is the new Corel drawing (yes, I had to learn to use 1 more program..) which will be final, and this is how the board came out Also, I will probably scrap those plexi backplates too, so I'll make a new more precise ones soon Link to comment Share on other sites More sharing options...
IMCustoms Posted April 5, 2015 Author Share Posted April 5, 2015 I hope Laser, CNC and Printer will be available tomorrow.. It has been a productive evening for me Link to comment Share on other sites More sharing options...
IMCustoms Posted April 8, 2015 Author Share Posted April 8, 2015 Text update time Great news all around today.. *Bitspower flying to the rescue once again* and they will probably cover those radiators I'm missing cause of EK. Cooler Master on the other hand is extending their sponsorship and they will give me some Jetflo and Silencio fans, and Vanguard 1000W Power supply on top of all of those peripherals I already got from them! And I'm waiting for a response to see if I will get a couple of SSDs, cause I only have 2 Intel's and I need 4 for this build. This is just a text update, cause I'm hard at work to finish everything on time, and I really don't have enough time to process the pictures of the work I did and post them.. So you will get one BIG update when I finish most of the work! Link to comment Share on other sites More sharing options...
chitoz Posted April 8, 2015 Share Posted April 8, 2015 good for you sir . bitspower is sure good staffs are just wow . btw pls check your message wanted to ask something Link to comment Share on other sites More sharing options...
IMCustoms Posted April 8, 2015 Author Share Posted April 8, 2015 Thanks christian dumdum, I will reply Link to comment Share on other sites More sharing options...
IMCustoms Posted April 13, 2015 Author Share Posted April 13, 2015 Had a little time to process some of the pictures and here is a "little" update Main board and plexi backplates finally together Pump holder and vent holes drilled trough horizontal boards Some bolts, nuts and holder ready for painting (shoe box cover), and sadly not all of them turned out great, so I will decide later what I'll do with them.. And finally I started mounting things on the wall.. This is the first support board: I drilled into the board so the nut won't stick out of it And this is from the other side of the wall, where it doesn't matter if everything sticks out: Light switch for my room was in the way of one of the support boards, so I had to make a hole for it (you can see that switch in my first design drawing) And both support boards are in place and leveled Link to comment Share on other sites More sharing options...
