InsolentGnome Posted March 20, 2015 Author Share Posted March 20, 2015 I've made some good progress this week, especially since I was destroying everything I touched last week. Cut the mounting tabs off the pump housing and put a nice coat of black paint on it to "fancy" it up Finished up my front panel. The grill is made of 3 layers of black screen mesh, 1 layer of aluminum screen mesh, and a bit of aluminum grill material. I was trying to give it a unique look similar to the bike(which does it with a radiator and a grill). Not the same, but I do like the look. So many wires! Soldering up the PCI-E cables. And much better. Nice little hard grommets I found at the hardware store, which lead to..... ....a mess right now. At least till I get the top finished. Working on the cooling loop now, should have more this weekend. Link to comment Share on other sites More sharing options...
InsolentGnome Posted March 24, 2015 Author Share Posted March 24, 2015 Progress, progress, progress. Ran the cooling loop. I'm going to be re-doing a few pieces. The glue for the Monsoon fittings looks horrible inside the tubing, and i didn't really get the knack for applying it till the last few fittings. Nothing will really change though. I did screw up and after cutting my last piece to length, realized I forgot to pull my piece of silicone out of the tubing. Damn. Getting ready to pressure test and crossing my fingers. And I hooked up the LED's while I was testing. I had to see what they would look like. I'm glad they're set up to be dimmed. Also did a little cable sewing to clean up the wires a bit. You don't really appreciate having a spot to hide wires til you have no place to stick them. And I finally finished the top of the case. Took a repaint and lot of sanding by finger, but totally worth it in the end. You can also see the grill that I covered in seat material. It was a tight fit. The original tolerances didn't allow any room for the material so I wound up bowing it a bit in the middle to get it in. You can also sort of see where the temp gauge is mounted to echo the instrument cluster on the bike. I'm happy to have been able to put this together in about 2 1/2 months. Nothing like working under pressure, huh? It turned out to be more work than I was expecting, and different from what I had planned(I was originally going to use a Cosmos SE but I couldn't get my hands on one). But looking at it now, I love how the Scout Advanced's top shape is sort of reminiscent of a bike's and I'm very happy with how it's turned out. Next up, doors. Sorry, fairings, and some decals. Link to comment Share on other sites More sharing options...
InsolentGnome Posted March 26, 2015 Author Share Posted March 26, 2015 And another tale of woe. Actually it isn't that bad, but I just can't seem to turn my back on this case, dammit. I was pulling my lines out to get ready to redo a couple and I ran into this. It's not super noticeable, but there is a fine crack on the right hand side of that collar. I had read a few forum posts about this but was hoping it was a limited occurrence. I have no idea what caused it, but the Monsoon hardline is out for now. And I really liked the look of it, plus I was comforted by there being more than the friction of an o-ring holding things together. Luckily I have the Primochill Ghost fittings and tubing I was originally planning on using. It sucks to have to completely change it over, but oh well, at least I don't have to worry about the glue like with the Monsoons. And I'm sort of digging the black lines. Maybe this isn't such a bad thing. Back to the measuring, cutting and bending board. Link to comment Share on other sites More sharing options...
InsolentGnome Posted March 31, 2015 Author Share Posted March 31, 2015 End of the month update. I'm mostly finished with only some details to add now, so let's get into it. Polishing up the sides. Man, it's hard to get that silver to really show in a picture. I'm hoping playing with some camera features will let it come out easier in the final shots. Side panel on. I like it! Also got the loop finished. I think the black looks better than the clear, just in that it doesn't draw your eye from the whole. That's important because I really didn't want this to be a mod with a couple of parts to focus on, but rather to be taken in as a whole. Which is good, because nothing I've done is new territory, but all together, it's something different. As far as my Monsoon fittings, Monsoon got back with me and discussed the matter and were pretty awesome about the whole deal. So, while I won't be using them in this build(2 sets of tubing was enough), I'm definitely going to try to use them in my next build. Some of the graphics on. Still waiting for a few to come in, last minute details of course, but sometimes you never know what you're going to need until you get it together and realize something's missing. Found my case a little sidekick. Although it'd be nicer to have the real thing to set it next to, this one was much, much more affordable. Probably one more update after this one, with some pics of the finished details and the lights and such running and then the final photos after that. 'Til then... Link to comment Share on other sites More sharing options...
InsolentGnome Posted April 14, 2015 Author Share Posted April 14, 2015 The last of my decals came in. Luckily in the mix, there wound up being an extra, because, well, let's just say I need some practice putting them on, lol. But I did manage to get some pics of it finished up. I'm not gonna call them my final pics, just finished. I still want to play with the lighting and get a few different shots. Plus, dust. I swear I wiped that thing down like 5 times! Link to comment Share on other sites More sharing options...
InsolentGnome Posted April 17, 2015 Author Share Posted April 17, 2015 Final Pics: Thanks for following along! Link to comment Share on other sites More sharing options...
EVIL PT Posted May 15, 2015 Share Posted May 15, 2015 Congratulations for the project, and for the second place. Best Regards Evil_PT Link to comment Share on other sites More sharing options...
