Inony Posted June 10, 2016 Share Posted June 10, 2016 Introduction ​​Hi everyone ​I'm Modder from Thailand. I'm not very good in English. Maybe have some word gone wrong. But I will try to communicate in the build log so that you can understand my job. For my concept "Ghost Rider" the reason I chose not because I like the hero. All the time I see that movie. I very enjoy when he was handle or driving the vehicle. Everything will change to new version on fire. It is charming and very aggressive artworks. I look forward and hoping he would do it again until the end.​ I want to change my old case to Bigbike concept. ​​By mixed​​ aggressive artworks form Ghost Rider vehicle.​ That is the origin of this work. Specs CPU: Intel Core i7-6700K MB: ROG MAXIMUS VIII Hero Memory: KLEVV Cras 16GB DDR4-3000 (4GB x 4) GPU: STRIX GTX 980Ti PSU: EVGA SuperNOVA 1000 G2 SSD: HyperX Predator PCI-e SSD 240GB Cooling: Cooler Master JetFlo 120 & Bitspower Picture when it finished. It has changed from the design of the program. Because each step mostly the work was done from handcraft. Case Modding In my opinion it is is no different from artwork. When start working, Everything maybe has changed over from origin design for the appropriate and perfect. Link to comment Share on other sites More sharing options...
Inony Posted June 10, 2016 Author Share Posted June 10, 2016 Build Log For this project, I choose any old case in my storage room. Pc case just a component, it isn't Tower mod. because it will be cut off until nearly entire. I used a few parts only.I pity to be well case to make. ​ After that, I made a rough design on the program but using actual proportions. This is my first design for set an overview of the work. I wanted to determine overall image for Structure and Possibility, from this you can see that I used only part of case. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 When got in shape overall. I began the next step by design the structure. I sketched it by hand on paper and simulation it up with water pipes that night. And began cutting pieces of steel welded together into a structure In the morning of next day. I cut a piece of steel by the size of models. While doing that, I have to bring case for try installed. This structure is completed as a draw sketched. It has a a little modified form, including the size for the appropriate. Although I have a program of innovative design. But when I work in each section I usually modify the model always and do it with my hands. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 I installed it into the case. Prepare for leading to cut by the next step. Then I cut to shape of case as designed. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 When main structure has been complete. The next step, I sketch outside part in the paper again. In design stage. There are steps calculation of the many things. In order to comply with the two main structures. But I did not take pictures hold. This picture not relevant to the Build Log. But it is the way to success of this project. I spent Five days to learning and working in the racing garage shop nearly. I think if we want to build parts of the vehicle on our casemod. We need to learn how to do it really from professional. After that we have learn how to do it already. I had comeback to make my case farring parts. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 I used MDF (Medium Density Fiber Board), Cut it off as a draw, Creating ridges And bring fabric stretched Attached with hot glue around the edges. To create a surface. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 For those who are uncomfortable using a motosaw. You can choose Plastwood, It's easy cut by cutter to made mockup for bring fabric stretched Attached with hot glue around the edges. For me I have tried it both ways the work was completed is the same. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 After mounting the fabric To create a surface already. Bring resins coatings to build strength.Repeat several times. When all the part is dried. Bring coating putty and polished with sandpaper until smooth. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 After I finished outsource parts. I bring the all of main structures to painting. Link to comment Share on other sites More sharing options...
Inony Posted June 11, 2016 Author Share Posted June 11, 2016 While waiting for the paint to dry. I went to The motor garage site for Build a exhaust pipe. By design it was intended to make the power cables coming from PSU come out on top. Next I cut acrylic, to put the motherboard. Link to comment Share on other sites More sharing options...
