Megadeblow Posted August 21, 2016 Author Share Posted August 21, 2016 Love how its coming out so far! I'm planning on buying this case for a mod as well. Thanks mate, sorry for the late reply, I have been ill Yeah the case if fantastic! and im not just saying that because they gave me it lol defiantly the best design I've ever had and its nice and functional. ------------------------------------------------------------------------------------------------------------------- Update ------------------------------------------------------------------------------------------------------------------- It's been a bad couple of weeks Contracted Sepsis last week so was taken in to hospital, just in time they said. I was really looking forward to maybe getting this build done in time for i58, but the chances are very low now, I'm also still awaiting the GPU so that will hold me back. The setbacks are not all bad though, this means I can spend a bit more time on the build and try something that I was not going to attempt if the build was defiantly on track for completion in time for the show. Had done some more paint work before my trip to hospital so I will upload them photos for you in the next update along with some work I did yesterday. I've also setup the components I have to check there all working as intended, so I'm happy to report the CPU, DDR, MB, PSU and water pump are all running fine. The MB looks beautiful! But the red will need to go and I plan to make a cover/covers for the MB. I did get myself some white plexi, however I think I will now be using clear so the LEDs on the MB can still be seen, if I paint most of the cover white and leave the parts covering the LEDs clear it should workout fine. Link to comment Share on other sites More sharing options...
Megadeblow Posted August 23, 2016 Author Share Posted August 23, 2016 Only needed to paint the edges here as all the other parts will be covered. Most the panels with the 1st coat of black. A quick wet sand ready for the 2nd coat of black, this will help show any high spots and imperfections in the base, you will notice most of the edges are high due to the case design and primer buildup. 2nd and final black base, this was also sanded after it was dry before adding 2x top coats that will need a week to harden before I can sand and polish, I hate orange peal on paintwork so its a must When complete I'm hoping the black will look like glass. Link to comment Share on other sites More sharing options...
Megadeblow Posted August 29, 2016 Author Share Posted August 29, 2016 Ok im back to work on the build after having a great weekend at the i58 event with some fellow modders and friends. I've been doing bits here and there on the case as I'm waiting for painted parts to harden. The base of the case is where I'll be having the pump, I decided to cut in to the PSU cover rather than totally removing it as it will help keep the case strong and be a good support for the pump and other bits. I made some templates for the bottom and side that will be used to make some covers out of plexi, this will also be painted or wrapped in white later down the line. Heres the panel cut to shape, all that's needed for now is a hole for the pump to sit in, some other cuts will be made after testing the layout. Now for the motherboard, its originally white, red and silver. I removed all the parts I wanted to paint and covered the red with some white wrap, the white did't match good enough so I went all out and painted the parts white. I wont be using the whole southbridge cover, but I've kept the G1 silver part should I decide to use it somewhere later. The motherboard is looking nice and clean, the white should look great with the light blue lighting once completed. I've also painted the RAM and some other parts like the EK waterblock shown in the photo below. I will get some more photos of them and the other parts posted in the next update. Link to comment Share on other sites More sharing options...
Sphinx818 Posted September 2, 2016 Share Posted September 2, 2016 Hey man! This project is coming along really nicely! Loving the attention to detail there Link to comment Share on other sites More sharing options...
Megadeblow Posted September 4, 2016 Author Share Posted September 4, 2016 Hey man! This project is coming along really nicely! Loving the attention to detail there Thanks, I see your also working on a MC5 mod Looking good! All the internal components and fittings are now painted, might add some more colour and or logos to them later in the build. Tron is very polished and simple yet effective, so I want to keep this as clean as I can. Here are some closer shots of the before and after CPU block. This is the backplate for the GTX1080 GPU, no white available so went ahead and painted a black one. I will be adding something extra to this later. Sound Cards repainted white with some added blue. This wont really be seen as the card faces down, but I still wanted to have it matching and hopefully the reflection will show once the bottom panel is added. For the pump I just needed to paint the rubber padding and the metal bottom. Here's the RAD, I think it looks great in white. Wont be needing to paint the fans for this RAD as they will be hidden on the other side. This is the fans for the double RAD going on the top, as it will be seen on the inside of the case I painted them. Link to comment Share on other sites More sharing options...
Megadeblow Posted September 4, 2016 Author Share Posted September 4, 2016 The most part of the internal layout. Some painted with acrylic and plasti-dip for the rest. I've made some covers for the bottom, sides and back that will all be painted white or wrapped once the wiring is done. Link to comment Share on other sites More sharing options...
Sphinx818 Posted September 4, 2016 Share Posted September 4, 2016 Thanks, I see your also working on a MC5 mod Looking good! Thanks man! Yeah it's in collaboration with Cooler Master South Africa and ASUS Republic of Gamers South Africa, it's going to be showcased at the largest tech and gaming expo in Johannesburg on the weekend of the 7th of October! So amped for it! Cannot wait to unveil it to the fans out there! Link to comment Share on other sites More sharing options...
Megadeblow Posted September 6, 2016 Author Share Posted September 6, 2016 Thanks man! Yeah it's in collaboration with Cooler Master South Africa and ASUS Republic of Gamers South Africa, it's going to be showcased at the largest tech and gaming expo in Johannesburg on the weekend of the 7th of October! So amped for it! Cannot wait to unveil it to the fans out there! That's fantastic! I wish I lived closer to some of the BIG gaming and modding shows around Back-plate for the sound card in place, used some velcro to hold it down as I will be needing to mess with it later in the build, its also a bit more tidy than using the screws on the card to hold it. got this cutter some years back for my model making, helps add some detail to the plastic, also very useful for cutting the plexi Bit wonky as it's not fastened in place just yet.. Same again for the back cover. Ordered some more white plexi, so most the parts will be re-cut using the old ones as a template. After some testing I decided to have the RAD facing the standard way rather than upside down. Just didn't have the room I wanted at the top for all the pipe and fittings. Link to comment Share on other sites More sharing options...
Megadeblow Posted September 9, 2016 Author Share Posted September 9, 2016 This has been the best part of the build so far, the results from the extensive paint coats, sanding, buffing and polishing have paid off, by far the best paint finish I've achieved with gloss. This has taken weeks, not a easy task especially with the sharp edged all over the panels making it very easy to take the paint of all the way down to the primer if not do perfect. This is the result after the gloss had been put down. Plenty of orange peal and although it looks shiny I cant stand the peal. So after the couple of weeks painting then sanding I got the gloss down and had to wait a week or so for the gloss to harden, then I carefully sanded down the gloss to get the surface as smooth as possible with paper. my hands looked like I had been sat in the bath for 2 hours lol Because I'm so happy with the result I will show you all a good handful of photos. Hope you like the result as much as myself and the next update will be installing some of the EL bits. Link to comment Share on other sites More sharing options...
Megadeblow Posted September 10, 2016 Author Share Posted September 10, 2016 Sound Card almost complete, just need to add something to the top plate. Link to comment Share on other sites More sharing options...
