tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 11/06/2019 Rebuilt everything, time to refill liquid and to make a new test, also for cpu loop. Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 13/06/2019 Aquasuite software configuration (sensors, alarms, led color change based on temperatures, fail safe switch for emergencies...) and 3DMark benchmark. Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 15/06/2019 Made a new Arduino project for the front panel motor: Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 09/09/2019 Time to cut top panel, for the new big motors. Motor hinges installed on radiator plate: Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 10/09/2019 New motor controller unit revision based on Crumbuino Mega with built-in RS485 chip, compatible with the new RS-485 motors installed on top and front panel. This new MCU revision got touch sensor for manually opening front and top doors, and also led mini display to get motor feedback (position, temperature, alarm error). In case of a negative feedback from motor (wrong position, high temperature, etc) the MCU will stop generating the rpm signal. At this point, the Aquasuite Quadro fan controller will not get the rpm and generate and alarm. Top panel hinges, first release in plastic: Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 13/09/2019 Time to cut retention clips from front panel (installed plastic hinges also on that): Motor placement for the front panel door: Front door installed and ready to be connected with motor: Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 14/09/2019 Motor control units revision based on Crumbuino board done (for cpu loop and cpu loop). Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 18/09/2019 Time to make some order inside the case, especially for cables and aquacomputer components. Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 19/09/2019 Ok, I'm obsessed with making order... now it's time to better place reservoirs, pumps and flow sensors. Link to comment Share on other sites More sharing options...
tdx79 Posted September 29, 2019 Author Share Posted September 29, 2019 WORKLOG 21/09/2019 Installed right side panel with double tempered glass. Link to comment Share on other sites More sharing options...
