Jump to content
AQUARIUM - linear actuators-driven water cooling 5K2K 21:9 mod
tdx79
  • Replies 38
  • Created
  • Last Reply
WORKLOG 27/09/2019
Cablemod led strips are great with their magnets, but I'd like to get a better light orientation...for example a 45 degrees, especially for the UV light to better "illuminate" the uv coolant flowing inside loop. So I got up with an idea: making a frame with a 45 degrees orientation for strips, and meantime using same fume Plexiglas for a better filters placement.
Link to comment
WORKLOG 30/09/2019
I made cables for touch buttons for opening front and top doors, and that will be connected to the motor control units.
Second step: front door drilling for the SPI2USB interface, board responsible for driving the Matrix Orbital lcd display (for showing system info).
Third and most complicated step: cutting the front door for lcd placement...
Link to comment
  • Create New...
Important Information
