Craig Ferrie Posted November 1, 2020 Author Share Posted November 1, 2020 Some large updates.Over the weekend, i finished the loop, ran a leak test and ran into several issues.Majority was recorded, and because of the leaks that happened, i just trashed the video.So looks like i'm skipping the build video and just moving to final images + Videos.At this moment in time, it's just touch ups here and there that are required, cables to moved around inside etc.Anyway, here's a couple shots from last night and a live video of the build that was done on facebook last night. [MEDIA=youtube]0X0lm1IrZVA[/MEDIA] Link to comment Share on other sites More sharing options...
Craig Ferrie Posted November 3, 2020 Author Share Posted November 3, 2020 Decided to upload some of the final images. Will post more detailed ones this weekend. In the image below, you can see 1 of the 2 filters that are in place to stop dust and debris from heading on into the loop. More to follow Craig Link to comment Share on other sites More sharing options...
Craig Ferrie Posted November 19, 2020 Author Share Posted November 19, 2020 #ontherocks What an incredible journey it has been. Thankfully and unfortunetly it is now finished. (Mixed emotions) Would like to thank our partners EK Water Blocks CableMod XPG Global ASUS Republic of Gamers AMD Gaming Jack Daniel's Tennessee Whiskey Without them, this project would NEVER have been possible. System Specs: ASUS ROG Strix X570-E Gaming Motherboard ASUS ROG Strix RTX2080 OC Edition MEMORY: XPG Spectrix D60G DDR4 16GB @3200mhz SSD: XPG Spectrix D40G M.2 SSD 512GB Cablemod: Custom made to order cables CPU: AMD Ryzen 3800X EK Waterblocks cooling list EK-CPU Block Lignum - Walnut EK-Quantum Vector Strix RTX 2080 D-RGB - Nickel + Acetal EK-Vector Strix RTX 2080 Backplate - Black EK-HTC Lignum 10/12mm Fittings - Walnut EK-CoolStream Classic PE 360 EK-Quantum Inertia D5 PWM D-RGB - Acetal EK-AF Classic Angled 90° - Black EK-AF Classic Angled 45° - Black EK-CryoFuel Clear (Premix 1000mL) EK-AF Extender 6mm M-M G1/4 - Black EK-AF ALU T-splitter 3F G1/4 - Natural Grey EK-CryoFuel Dye Pack EK-HD PETG Tube 10/12mm 500mm Be quiet! Dark Power pro 11 1000w power supply Extras Cooler Master MasterFan SF360R ARGB 360mm Premium Riser cable No return valves (Under shroud) Soft tubing for valves (under shroud) Custom 15cm USB Extensions Custom Kettle plug Extension 22 wooden slats 12 A4 size birchwood sheets Jack Daniel's Bar mat Jack Daniel's Tumblers Jack Daniel's 1L Whiskey Bottles The system has 2 reservoirs that are interchangable. One = Closed loop, no evaporation or dust. Two = Open loop, water falls from bottle to glass. (for show event use) I know it's not a winner here at the world series, but it's a winner here at home. Good luck to everyone entering, may the odds be ever in your favor. Craig Link to comment Share on other sites More sharing options...
E x e Posted November 19, 2020 Share Posted November 19, 2020 i like it a lot Craig, so much details and flawless execute, nicely done, cheers Link to comment Share on other sites More sharing options...
Craig Ferrie Posted January 15, 2021 Author Share Posted January 15, 2021 BENCHMARKS! So.. First run, was box standard with NO overclocks at all. Pretty basic score. After this i ran a CPU Overclock. Managed to pull an extra 32 score. Finally i put the GPU's core clock & Memory clock up by +200 each. And managed to pull over 800 more score. This overclock ultimately puts the system higher than a ''High-End gaming PC'' in the rankings. - This post is for the NVIDIA sub catagory. Link to comment Share on other sites More sharing options...
