Andrey Bukhtiyarov Posted December 22, 2020 Author Share Posted December 22, 2020 59 minutes ago, Xing said: For fans on the side, is the 92x92x15mm the recommended dimension? Do you know the limitation? Ā Thank you I tried 20mm and 25mm, thos heights displace PSU holder a little to front and cables from PSU became to close to front glass window. So, I selected height only 15mm. Link to comment Share on other sites More sharing options...
Xing Posted December 31, 2020 Share Posted December 31, 2020 On 12/22/2020 at 4:35 AM, Andrey Bukhtiyarov said: I tried 20mm and 25mm, thos heights displace PSU holder a little to front and cables from PSU became to close to front glass window. So, I selected height only 15mm. Thanks for the explanation. Ā I started receiving parts and began putting themĀ together. The two things that worries me the most are the clearance forĀ AIO cooler and RAM. The Z53 AIO that I have is quite thickĀ with 52.4mm water block height and 30mm radiator height. I did a test fit and was able to stuck that in between the PSU holder and case. The side touchingĀ PSU holder cannot fit with protruding screws, so I left that unscrewed. I'm still looking into ways to secure the AIO cooler similar to yours. I was able to close the top panel without cutting the extra plastics for included fans, but I might remove them purely for aesthetics.Ā Ā Once my motherboardĀ arrives, I will report further results later. Ā Ā Link to comment Share on other sites More sharing options...
Ron Legas Posted January 29, 2021 Share Posted January 29, 2021 On 1/1/2021 at 4:24 AM, Xing said: Thanks for the explanation. Ā I started receiving parts and began putting themĀ together. The two things that worries me the most are the clearance forĀ AIO cooler and RAM. The Z53 AIO that I have is quite thickĀ with 52.4mm water block height and 30mm radiator height. I did a test fit and was able to stuck that in between the PSU holder and case. The side touchingĀ PSU holder cannot fit with protruding screws, so I left that unscrewed. I'm still looking into ways to secure the AIO cooler similar to yours. I was able to close the top panel without cutting the extra plastics for included fans, but I might remove them purely for aesthetics.Ā Ā Once my motherboardĀ arrives, I will report further results later. Ā Ā Good day. I also have the Z53 as my AIO, so I'm definitely looking forward for your update. Wishing you all the best! Link to comment Share on other sites More sharing options...
Ron Legas Posted June 28, 2021 Share Posted June 28, 2021 On 1/1/2021 at 4:24 AM, Xing said: Thanks for the explanation. Ā I started receiving parts and began putting themĀ together. The two things that worries me the most are the clearance forĀ AIO cooler and RAM. The Z53 AIO that I have is quite thickĀ with 52.4mm water block height and 30mm radiator height. I did a test fit and was able to stuck that in between the PSU holder and case. The side touchingĀ PSU holder cannot fit with protruding screws, so I left that unscrewed. I'm still looking into ways to secure the AIO cooler similar to yours. I was able to close the top panel without cutting the extra plastics for included fans, but I might remove them purely for aesthetics.Ā Ā Once my motherboardĀ arrives, I will report further results later. Ā Ā Good day! Sorry for asking but I was just curious about your build. We have the same aio and I was also planning on doing this mod. Did you get around finishing it? Did the z53 fit inside the case? Hoping to get a response from you. Thanks! Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
