Jump to content
Cyberpunk 2077 - Deconstruction
AKMod
 Share
Spray paint
This modification involves a lot of spraying operations.
Mantis Blades primer is completed, start detail processing, masking spray.
Parts of the repair stand start painting.
After the rusty inner layer is finished, sprinkle salt and add water!
Bottom old effect treatment
Edited by AK Mod
  • Like 2
  • Upvote 1
Link to comment
Deconstruction table
Perform detailed 3D drawing, which will include CNC, lathe, and laser cutting processing.
The design progress is roughly 95% completed.
The ring scanner will have infrared function, and the machine will move laterally when turned on and off!
  • Like 3
Link to comment
Component
The touch switch and LCD screen base are completed!
The upper cover part of the repair table is completed.
I want to have a hierarchical concept so I used 5mm, 8mm, 10mm acrylic.
  • Like 4
Link to comment
Components
EL light guide plate, used to present the feeling of the product name at the bottom.
Micro putter, link scanner base.
Anti-scalding cloth, which will be used to wrap copper pipes.
Added a control box to place the PCB board, integrate the small parts and include the VDF cold light display.
Power shield.
  • Like 1
Link to comment
Component
CNC 20mm acrylic double-sided processing, 3 stacked decorative props.
Light guide plate.
Fan exhaust cover.
Control box aluminum base plate.
1.5mm aluminum plate, grooved and bent.
  • Like 3
Link to comment
Damage
The scratch effect of the substrate is completed, and then start to make the details, and finally the overall old surface treatment.
The primer spraying on the cover of the repair table is completed, and then the top coat is sprayed and the old effect is treated.
Edited by AK Mod
  • Like 2
Link to comment
Detail
Refer to some patterns on Mantis Blades, use UV printing and laser engraving to restore the sense of reality.
Designed some fonts suitable for the theme.
  • Like 4
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
 Share
  • Create New...
Important Information
