Jump to content
Inony - RX-0 destroy
Inony
This contest I have 2 months to work before Final Submit.Together with the outbreak of COVID 19. There are lockdowns and curfews in my province. I had to trick my friends came to help. Become a special COVID-19 victims team. By dividing work together according to the aptitude of each person.
In which I [Inony] will write all the 3D work and send files it to my friends [Suchao Modding] to print and scrub the surface then spray the main color. After that, take it to airprush to create Shading with his wife. The three of us have been friends for a long time. But never worked together It was a fun experience.
After making plans.This work is a hard challenge for me. Usually, I will write everything in 3D to finish. Therefore began to work. But this time is different. After I finished just a head. Printing must be start to complete the work on time. No overview, No time to edit designs, I have to work against time. While my friend was printing I have to finish the next part. So as not to make the machine unemployed. I had to write a race with 7 machines Printing at the same time. We work together as a gear.
Any piece that is finished, then take out the support and scrub the surface.
Link to comment
Exfoliating the skin smooth is tough for PETG filament. But my partner did it very well.
😮 This is his secret, how to get smooth skin.
1. Scrub the skin with a sandpaper.
2.  Paint the skin with putty.
3. More scrub the skin with a sandpaper.
4.  Paint the skin with more putty.
5. More and more scrub the skin with a sandpaper.
Actually, I see two things over and over again. I feel very pity. So I decided to help him by walking to buy more sandpaper.
Link to comment
Finally, my friend was successful. With handling the surface of the workpiece 🥳
Until I realize. When the drawings are completed in the set time of month, the number of parts is 200+ pieces.
Fortunately, I don't have to be a scrub at all. The amount of it is a lot for work just  80cm. x 80cm. Thanks, mate!  😆
Link to comment
When everything is fine Then take each part separately to color according to the main color. To prepare for the next step of airbrush and Decal.
I will come back to update again. If the steps are not detailed Anyway, I'll add a video when it's done.
  • Like 2
Link to comment
After doing the main color, the next step is draw lines. We're draw lines by hand on every piece.
Some points that cannot be dragged through Use the brush Dip the paint to let the paint flow along the groove.
Link to comment
Use the airbrush for shading to create shallow-depth that will make every pieces stand out more.
Some points that need light to illuminate from the inside.  With shapes that cannot be created with acrylic. We build them with resin print. Then coated with candy tone color
The metal shad group was successfully painted.
Link to comment
The next step is the decal part. It is very difficult to get out of the house. And in my province don't have a water decal making shop. So I used a regular sticker and cut it with my machine. It is very difficult to paste because the letters are extremely small. But it's not my problem. I just cut it and send to my friend to paste it.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
Important Information
