AeGis Posted September 27, 2009 Author Share Posted September 27, 2009 update 27/09/52 For side wall of the case. This is a clear lid to. I think that will put a logo into the middle to increase interest by using the laser inserted into the destruction of Acrylic. Link to comment Share on other sites More sharing options...
AeGis Posted September 29, 2009 Author Share Posted September 29, 2009 Link to comment Share on other sites More sharing options...
PaPang Posted September 29, 2009 Share Posted September 29, 2009 This is the first time I see a laser cutter in action! Is it yours? Cheers and Saludos Link to comment Share on other sites More sharing options...
AeGis Posted September 29, 2009 Author Share Posted September 29, 2009 This is the first time I see a laser cutter in action! Is it yours?Cheers and Saludos Yes it is a laser cuter Link to comment Share on other sites More sharing options...
AeGis Posted September 30, 2009 Author Share Posted September 30, 2009 Then came the step I am the most stubborn case of milling this is made after the case lid. I can set the following. 1. Demonstrates a Thai art. A type of sheep in a stone. 2. To work hand-in edge side. 3. To use a different line to collect. 4. The difference is not unique. ********************** I could have designed a new side wall. Eha issued by the then new. If ordinary square cut. Nothing new I would come to no design pattern is a serpent. To show the beauty of art. This process is time-consuming process that most of all I have is that because the process is relatively very difficult to garner. To switch to sheep by laser. Link to comment Share on other sites More sharing options...
AeGis Posted September 30, 2009 Author Share Posted September 30, 2009 Later, with the striped side of the case the light pattern is protagonist. Link to comment Share on other sites More sharing options...
AeGis Posted September 30, 2009 Author Share Posted September 30, 2009 ater combined with the screen LCd put in the box 3.5 "to show the status of various machines. Link to comment Share on other sites More sharing options...
AeGis Posted September 30, 2009 Author Share Posted September 30, 2009 Take me to the vertical section of exermax. Can tell at the landscape industry has been able to adjust the fan. So easy to use. Link to comment Share on other sites More sharing options...
AeGis Posted September 30, 2009 Author Share Posted September 30, 2009 Then it's time for a different part of Toshiba attributed together. Link to comment Share on other sites More sharing options...
AeGis Posted September 30, 2009 Author Share Posted September 30, 2009 My system to install in case. Cpu : Intel Dual Core E5200 Cpu Cooler : Cooler Master V8 Mainboard : Gigabyte EP45-Extreme Ram : Kingston Hyper X DDR2 Bus 1066 VGA : Palit HD4870 Sonic 512MB 256Bit Harddisk : Westen 320GB SATA2 Raid0 Power Supply : Gigabyte Odin 550W GT FAN : Cooler Master 120mm Link to comment Share on other sites More sharing options...
