Peter Brands Posted February 22, 2011 Share Posted February 22, 2011 ----> Click here for the post with 48 of the final pictures ! <---- Now also linked to the original 3900x2600 photo's ! Hi there:) I'm quite new to this forum, but since they liked my build at some Dutch hardware sites, i wanted to post it here too. My other build came to an end and didn't know what to improve, but my old desk almost fell apart. Really want to thank Pascal for his pc-in-a-desk idea. After seeing it I couldn't even sleep that night I started sketching it with Google Sketchup After 9 hours of non-stop drawing it finally had some shape. Hardware to be used: (Most of it comes out of my old build) Intel Core i7 980X @ 4.5 Ghz Corsair Dominator GT 6GB DDR3-2000 CL7 (Elpida) @ 2000 7-7-7-20-1T ASUS Rampage III Extreme 2 x ASUS GTX580 ASUS Xense Sennheiser Xense Highpoint RocketRAID 3560 24x SATA-300 2 GB Bigfoot Networks™ Killer™ 2100 Gaming Network Card 1x Intel 510 120GB 3x Corsair F60 raid0 6x Hitachi Deskstar 7K2000 2TB raid5 2x Optiarc AD-7241S-0B 2 x Coolermaster Silent Pro 700W Dell U2711 27″ IPS 2x Dell 1703 FPt 17″ portrait Blocks 1 x EK Supreme HF Nickel CPU Block 2 x EK-FC580 GTX – Nickel 2 x EK-FC580 GTX Backplate – Nickel plated 1 x EK RAM Dominator Nickel 1 x EK-FB RE3 – Nickel 1 x EK-FB RE3 – TOP Acetal – Level 2 2 x Bitspower HDD Acetal Liquid Cooling Block – Silver Pumps 2 x Laing D5-MCP655 2 x Bitspower D5/MCP655 Mod Pump Top V2 2 x Bitspower Black Sparkle D5/MCP655 Mod Kit Reservoir 1 x Aquacomputer Aquatube G1/4 brass Radiator 1 x Aquacomputer evo 1080 Fans 6 x Nanoxia DX Series 120MM DX12 - 1200RPM @ 5V 11 x Scythe Gentle Typhoon 120MM 1450RPM @ 12V Fittings etc 24 x Bitspower Black Sparkle Multi-Link (SLI/CF) Adapter 16 x Bitspower Black Sparkle G1/4 Rotary 90 Degree IG1/4 Adapter 12 x Bitspower Black Sparkle G1/4 naar G1/4 (2x OD) Verbindingsstuk 10 x Bitspower Black Sparkle G1/4 Stop Fitting 8 x Bitspower Black Sparkle 13MM (1/2) Schroeffitting – G1/4 6 x Bitspower Black Sparkle G1/4 Rotary 90 Degree ID 1/4 Adapter 6 x Bitspower Black Sparkle G1/4 IG1/4 Extender 4 x Bitspower Black Sparkle G1/4 Five Rotary Snake-Style Dual IG1/4 Adapter 4 x Bitspower Black Sparkle G1/4 Rotary 45 Degree IG1/4 Adapter 2 x Bitspower Black Sparkle G1/4 Triple Rotary Mini Snake-Style Dual IG1/4 Adapter 1 x Bitspower Black Sparkle G1/4 Triple Rotary Snake-Style Dual IG1/4 Adapter 1 x Bitspower Black Sparkle G1/4 Rotary IG1/4 Extender 5 x Bitspower Crystal Link Tube For 5-Slots (SLI/CF) 8 x Bitspower Silver Shining 2xG1/4″ Fillport 2 x Bitspower Silver Shining G1/4 naar G1/4 (2x OD) Verbindingsstuk Mini 2 x Bitspower Matt Black 2xG1/4″ Fillport 2 x Bitspower Matt Black 13MM (1/2)Schroeffitting – G1/4 1 x Koolance INS-FM17 Coolant Flow Meter & Adapter Board INS-FM17 2 x Thermosensor G1/4 2x ID In-Line met Display (blue) 2 x Colder 13MM (1/2) Snelkoppeling Set 2 m Tygon R3400 1/2 ID Black 2 m Tygon R3603 1/2 ID Clear 3 L Feser One Cooling Fluid – UV Acid Green I'm also gonna use my old cooling again since it works superb. It's a 1080 radiator under my floor from my house, right in the corner where my pc is. My water temperature in wintertime is around 18 degrees, in the summer it's around 23 degrees. Here some Youtube movies: Underground radiator The Final Fill-up Silence of the L3p D3sk Sponsored by: Link to comment Share on other sites More sharing options...
Peter Brands Posted February 22, 2011 Author Share Posted February 22, 2011 Since im already busy with this project for 7 months now, here are all the pics in a few posts. Started with an Aluminium plate of 1850x990x3 Plates for the mainboard tray, hdd tray, pump/res tray and cable plate The bearer ring to hold my desk Been to an other company to make a logo And back to welding Plasmacutter to make some cable holes End of the first long day Creating a logo (was just a try, worked out well) Made some holes for the lcd's for the in and outgoing water temperature, and for the logo Had to make some changes to let my knees fit Fitting the trays with sound isolation under it. I love packages ! Thought the buttons would the same, gonna change for 2 big one's now. Sound isolating for under my trays. My best friend welding Holes for the Bitspower fanguards Both sides will have 3x 120mm Scythe Gentle Typhoons 1450 rpm op 5V Underground will be 9x 120mm Scythe Gentle Typhoons 1450 rpm op 12V @ the 1080 radiator Thats me ! "Rough" work is done A Bitspower Black Sparkle Ashtray So brought the d3sk back home Gonna use the backplate of an old case. (Thanks brother in law !) Fitting, measuring and hanging The battlefield. Just playing around New toy arrived Forgot a hole Mess outside Made 2 extra 120mm fan holes in the cable-space, cause i decided my psu will come there too. And made the hole for the lianli backplate. Bitspower ! And building everything back for the hole picture Link to comment Share on other sites More sharing options...
Peter Brands Posted February 22, 2011 Author Share Posted February 22, 2011 Shopping time Measuring the last holes. And more measuring Muscle pain ! Rear = ready And the front ! Hiding cables, what a nasty job. Scythe fanguards, maybe temporary Need sata ? Topview Getting tired when i see this again Filled up ! Hiding Sata(n) ! And lift of Testrun 1 Temperatures are better then in my old case Now first some rest behind my d3sk Found a nice connector for the Bulgin power and reset button to be disconnected easily. That's me ! Done for today Link to comment Share on other sites More sharing options...
Peter Brands Posted February 22, 2011 Author Share Posted February 22, 2011 And some new hardware Supreme HF Nickel + Chrome I'll add these in my loop the next time Link to comment Share on other sites More sharing options...
Peter Brands Posted February 22, 2011 Author Share Posted February 22, 2011 Other mem set to play some with the fsb for a 24/7 OC Been running with this without any problems for 2 weeks now. Blue 2 x 120 cm SMD Led + UV 3 x 120 cm SMD Led Personally i like this the most New set of Corsair mem First time playing with plexi Found a Corsair Dominator GT 2000mhz CL7 elpida set. Looks easy, but isn't Old and new set Also added an UV Led strip behind the logo to lighten it up some more. Without UV Led With UV LED Without UV Led With UV LED Link to comment Share on other sites More sharing options...
Peter Brands Posted February 22, 2011 Author Share Posted February 22, 2011 How it was How it looks now And bought some blocks from a friend, im totally in love with plexi now Breaking it down. Removed teh old SMD leds. Ohhh no ! Oh never mind Been puzzling for 1.5 hours before i had the right combination. Cleaning time. Dirt ! L3pping the 980x 30 seconds @ P400 already tired 5 Minutes P400 - Total 5 Minutes 5 Minutes P400 - Total 10 Minutes 10 Minutes P400 - Total 20 Minutes 10 Minutes P400 - Total 30 Minutes 15 Minutes P400 - Total 45 Minutes 10 Minutes P600 - Total 55 Minutes 10 Minutes P800 - Total 1 hours en 5 Minutes 10 Minutes P1000 - Total 1 hours en 15 Minutes 10 Minutes P1500 - Total 1 hours en 25 Minutes 15 Minutes P2000 - Total 1 hours en 40 Minutes 20 Minutes P2500 - Total 2 hours Had to play some with the cam Results Idle Stressed And finally ... Building it back asap, im tired And some pics. Link to comment Share on other sites More sharing options...
Peter Brands Posted February 22, 2011 Author Share Posted February 22, 2011 Tomorrow even more pics Have fun 1 Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted February 22, 2011 Share Posted February 22, 2011 Very nice guy your project, have equipment that I never looked. kkkkkk Link to comment Share on other sites More sharing options...
mcj66106 Posted February 22, 2011 Share Posted February 22, 2011 Hey its good to see you here. Good luck with the build. Looks great. Link to comment Share on other sites More sharing options...
Peter Brands Posted February 23, 2011 Author Share Posted February 23, 2011 Thanks guys Link to comment Share on other sites More sharing options...
