Jump to content
Scratch Build : L3p D3sk - Small update :P 15-7
Peter Brands
  • Replies 113
  • Created
  • Last Reply
Hola L3p!
Always good to see another take on the "desk pc", very impressive and excellent work! It would be one way for my wife to quit complaining that I am just piling up mods in a closet. I would regret it if she made me move it somewhere else, hehe.
Kudos for a great project and +1 for execution!
Cheers and Saludos
Link to comment
Here some pictures of the conversion.
Even on air they are lovely.
But i love WC blocks :P
You can easily spend a hole evening on 2 cards.
And thats 1
And thats 2 :)
Replacement part came in the next morning :)
Quite an impressive block, it has 4 O-rings in it
And now the adjustments for the bigger mainboard and the extra needed cables for the gpu's
Had to do everything by hand cause i didnt want to clear the hole desk
Also the mainboard tray needed some work.
Discs specially aluminum.
And done.
Now i can start fitting in the Bitspower parts
Every SLI connector has to fit exactly.
One of the many times fitting it in the desk.
Only one connector to go.
Got the tip to polish the silvercoil :)
Hmm..
But it's shiny again :)
Cable for the extra molex on the Rex3.
After one hour i finally found a way to get all the cables under the mainboardtray
And some teasers for later this week :)
When looking for the newest bios for the rex3, i also found a driver for symbian phones.
I had no idea this was so easy :)
Link to comment
  • Create New...
Important Information
