Jump to content
Scratch Build : L3p D3sk - Small update :P 15-7
Peter Brands
Been playing with a lot of stuff this weekend ;)
Testing with the 2 (3) PSU's
Total of 2600W running now.
And off course my 3.3V 5V and 12V are superb now :)
Very silent psu's by the way !
Even under full stress :)
980x @ 4.5 Ghz + 2 x GTX580 @ 960/1150
And creativity with Bitspower on a Sunday afternoon :D
It was to see the effect of flowing Acid green right under UV leds in the desk.
(For further plans ;) )
Link to comment
  • Replies 113
  • Created
  • Last Reply
Needed for the Coolermaster PSU's
After the mouse i was looking for a fitting mousepad for the desk.
Personally i like cloth pads like the Q-pad.
Couldn't find anything at all.
All i could find was a pad with leds in it.
But then the idea popped up ..
Still had some plexi somewhere, and there are 150 UV smd leds in my desk so why not try it :P
The plex.
(Fits perfectly !)
The "hard" SLI connector.
And my RVS cupholder :)
With a jigsaw.
Maybe im going to let the print melt down into the plexi with its pins
The Q-Plex :)
And the ...ehm ..cupholder :)
Still goin to polish them some more later.
Link to comment
  • 2 weeks later...
Still had to change some things under my floor.
Today i found some time.
Had to replace some fans on my rad for Scythe GT's
Replaced the green tube for Tygon black.
Also replaced the 3 remaining GT's in my desk for green Nanoxia's
GT's out
Only 5cm space for my hand.
Nanoxia's in.
Here my radiator in the distance.
On request also made a little movie of my trip :)
Mobile doesn't work here, but baby phone works fine :D
De GT's on their place and tubes replaced !
And another small test.
Wanted to know what stuff goes trough my loop.
This way it was easy to discover.
Click it between my tubes and enable the pumps for one hour.
Then disconnect the filter while pumping and stop the pumps as fast as you can.
This is so the dirt really stays in the filter.
All tiny hairs and wtf, even a piece of my sigarettes :P
Till next time :P
Link to comment
The date for powder-coating the desk has set !
Next week Tuesday ill bring it over there :P
10 minutes before unplugging it
And 3 hours later :)
Also took me half an hour to think how i will place the second PSU.
Decided to place them like this, ill creata another 120mm fanhole between the psu's tomorrow
Wanted to use these for my quick connectors outside the desk
Maybe till tomorrow :P
Link to comment
Yesterday the idea came up for hiding my cables from the 3 screens.
Some won't like it, but for me this works great since my pc is more open then closed :P
So this way it's very easy to take away the backplates.
It's only connected with the left side of the panel.
2 hours later it was really empty, looks like a reverse buildlog :(
Sanding it some.
Like a bomb exploded.
Here i was finished for today :)
Link to comment
  • Create New...
Important Information
