Deblow Posted March 24, 2014 Author Share Posted March 24, 2014 Again, Sorry for the photo qualitythe final stage photos will be higher standard, but i wanted to give you a good idea what the build was like from the start Link to comment Share on other sites More sharing options...
Deblow Posted March 24, 2014 Author Share Posted March 24, 2014 Adding black paint to help the carbon wrap stick better around the glass top slot After lots of messing and 1 or 2 tea breaks the wrap was almost on (1st test build) Desk has been taken apart in order to fit new items and make other changes. One of the hardest parts (carbon wrap) over with and the toughened 6mm thick glass fitted Link to comment Share on other sites More sharing options...
Deblow Posted March 24, 2014 Author Share Posted March 24, 2014 my wife is very happy now most the house is getting back to normal & shes not having to clean-up saw dust & paint every day lol the green base under the RES in the photo above has been remade 4 times so far due to changing the tube placement, 1st & 2nd was black, 3rd was green, 4th is now black & im sure i will be remaking it again soon when i change pump & add 2nd RES. the wrap is 4D, but its hard to show the effect in the photos. Link to comment Share on other sites More sharing options...
Deblow Posted March 26, 2014 Author Share Posted March 26, 2014 right now im rebuilding the desk and making some changes, i was almost done with the build but i have the parts needed to watercool the GPU's here are the EK compression fitting i wll be using for most connections Link to comment Share on other sites More sharing options...
Deblow Posted March 26, 2014 Author Share Posted March 26, 2014 The EK-FC R9-280X Matrix - Water Blocks Link to comment Share on other sites More sharing options...
Deblow Posted March 26, 2014 Author Share Posted March 26, 2014 Here are the Graphic cards i will be using along with the blocks, Asus Matrix 7970's Link to comment Share on other sites More sharing options...
Deblow Posted March 26, 2014 Author Share Posted March 26, 2014 Using the G1 Sniper 3 motherboard, one of the reasons i went for green and black My RAM, also green and black And to power all this and more i went for the a monster PSU the Coolermaster V1000 Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 I will be using 2x EK-CoolStream RAD XTX (360) in final build Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Here's the pump i will be using in the final build, hoping to lay it flat under the RES Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Working in the LED strip lighting that will go in the shelfs and behind the top glass shelf Link to comment Share on other sites More sharing options...
