Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 You can just about see the LEDs for the matrix cards on the sides near the volts - + buttons they can be moved around a bit but i think they look best on the sides Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 here's the pullout I've made, used the runners from my old ikea draws, and covered the wood with some fake leaver (Flux) Made a curve in the back so theirs room for wires to drop down the back if needed the cup is misleading, it was a nice pot of tea Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 making a small block to house 2 switches, one will control the LEDs for the lower shelf's and the second will control the LEDs on glass shelf above the desk top. i will be placing it under the desk more than likely just below where the mouse mat sits made from my trusty Ikea wood Clips i will be using Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 This is the prototype for the wire cover, will see how it looks when I've remade it a bit more solid and covered with whats left of the carbon For now its doing the job, just clips on and off very easy Also decided to cover my glass shelf with carbon because it was a bit too bright even with LEDs on lowest setting, Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 Due to bad weather and a wet shed iv had to put the cover on hold, I've started on some other bits that i can safely do in the kitchen My first attempt with perspex and a multi tool, small black EK logo bridge not sure if this will be the final one but so far im happy with it Artwork done on the PC, then printed some different sizes to see what looked best Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 still needs a bit more trimming, the inside is UV green forgot to mention, i decided to move the matrix LEDs to the top as they was effecting the UV lighting Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 Switches for top & bottom shelf LED's now in place, not the best but will do the job for now Top shelf in place (day) Night Can be changed to any RGB color along with the RES and bottom shelf's Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 Wrap now fitted to the glass shelf, no room for error here as the wrap sticks to glass really fast and its very hard to remove without heat Link to comment Share on other sites More sharing options...
Deblow Posted April 8, 2014 Author Share Posted April 8, 2014 Side cover now remade, snaps on to cover the MB cables Link to comment Share on other sites More sharing options...
