chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 will be cutting holes for the placement of the mobo 20150408_145510 Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 i lower the resolution of the picture to 1600x1200 i think 2048 by 1536 is big first cut hole . 7 more to go 20150408_145514 Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 so i cut an piece for the front of the case 20150408_171327 Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 now measuring at the back of the case 20150408_181854 Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 sanding is soo hard -.- took a couple of hours to just make it near straight 20150408_190023 Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 now cutting 4 holes for the placement of the mobo 20150408_192020 using dremels attachment very usefull Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 now its done Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 now placing it on the case and measuring it where to go Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 just want to share my 2nd work space . its raining btw Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 drill holes at the back of the mother board placement then put some bolts and done btw im still going to cut the extra metal on right side Link to comment Share on other sites More sharing options...
