chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 now its raining hard but still mod on Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 now going to cut it with dremel and place two cutting disc . because it will be strong as funk now its done . .. . . cheese Link to comment Share on other sites More sharing options...
chitoz Posted April 9, 2015 Author Share Posted April 9, 2015 now i sand the edges then place the acrylic at the back and i drilled the holes and place some bolts and then done still need to sand more but its night need to rest Link to comment Share on other sites More sharing options...
chitoz Posted April 17, 2015 Author Share Posted April 17, 2015 so im going to cut and hole for easy installation of the cpu cooler bye jigsaw blade/bullet and done Link to comment Share on other sites More sharing options...
chitoz Posted April 17, 2015 Author Share Posted April 17, 2015 and cut the extra piece on the mobo placement bought some bolts ( god dammm expensive -.- ) so im going to cut an acrylic piece for the front done Link to comment Share on other sites More sharing options...
chitoz Posted April 17, 2015 Author Share Posted April 17, 2015 so im going to cut for the side of the inside of the case now i was running out of acrylic good thing a friend of mine give this to me 4mm then done then cut another piece for the other side of the inside then place all of it in the case Link to comment Share on other sites More sharing options...
chitoz Posted April 17, 2015 Author Share Posted April 17, 2015 sorry for the pic . not proper focus and no light broke 2 lights because of the wind that blow my light stand done . . . Link to comment Share on other sites More sharing options...
chitoz Posted April 17, 2015 Author Share Posted April 17, 2015 so i need to cut this for space for the fans done Link to comment Share on other sites More sharing options...
chitoz Posted April 19, 2015 Author Share Posted April 19, 2015 so my uncle give me this 20150418_134158 tbh this is one tough steel . so will be cutting this for the top of the case where the fans go 20150418_150226 after 2hrs of work its done 20150418_225345 Link to comment Share on other sites More sharing options...
chitoz Posted April 19, 2015 Author Share Posted April 19, 2015 so i recycled an acrylic . because i ran out of acrylic sizes so will be using this . but some brackets on the side for the mounting it in the case . then place the fans that i will use and drill holes in it after 3hours of work . its done but sadly i broke a fan -.- Link to comment Share on other sites More sharing options...
