GP Modder Posted October 10, 2020 Author Share Posted October 10, 2020 (edited) Edited October 10, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 10, 2020 Author Share Posted October 10, 2020 (edited) I had to test the radiator today. There were no tools for it. I figured it out An idea for those who are building their first water cooling system and there is no pressure-test set nearby. I built such system many times, but I didn't see the point in investing in one, I trusted myself. But it can be useful, I needed it now because the radiator that I install in my current machine has been used here and there for a couple of years so I thought I'd test it now before installing to avoid any complications when the computer is finished. So the ingredients: 1 car tire valve (Schrader valve) 1 locking screw to close the end of the system. 1 x 13 hard tube fitting (I use Alphacool.) 1 bicycle pump with pressure gauge You connect the fitting to the other end of the system, unscrew the nut, insert the small rubber valve with a valve needle through it and you screw it back into place. The bottom also sits right into the fitting. You connect the pump and inflate gently as you feel, I used 1 bar of pressure. If all is well, you can bleed the air from the system by pushing on the top of the valve needle. Edited October 10, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 12, 2020 Author Share Posted October 12, 2020 (edited) Bottom decorative slats made. The H100 frame is ready. Edited October 12, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 12, 2020 Author Share Posted October 12, 2020 (edited) Sandblasting time. Edited October 12, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 12, 2020 Author Share Posted October 12, 2020 (edited) matte black powder coating. Edited October 12, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 13, 2020 Author Share Posted October 13, 2020 (edited) Intel I3 or I5 ? I thought a lot about which one was better. GPU 1660Ti 6GB I talked to some OC friends and the decision was made. I3 9350KF Edited October 13, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 13, 2020 Author Share Posted October 13, 2020 (edited) UPS package received. Thank you again for your support of Alphacool. This is the 3rd time that I can enjoy their full support. Thank you very much, I am honored to have this trust. Edited October 13, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 13, 2020 Author Share Posted October 13, 2020 (edited) This Alphacool unit is so beautiful that I install it as an external component. I make the console from wood, which is placed on the bottom unit. Edited October 17, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 17, 2020 Author Share Posted October 17, 2020 (edited) Fixing a radiator to the bottom frame is today’s task. 2mm steel plate with water cut. I will paint it black later. Edited October 17, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 17, 2020 Author Share Posted October 17, 2020 (edited) Edited October 17, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
