GP Modder Posted October 4, 2020 Author Share Posted October 4, 2020 (edited) I drilled the holes for the tightening clamps on the final bottom panel. Edited October 9, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 7, 2020 Author Share Posted October 7, 2020 (edited) Reinforcement of the rear frame with aluminum profiles. I also adjust the side glass to this. Edited October 9, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 7, 2020 Author Share Posted October 7, 2020 (edited) Attaching the rear stiffener. Leveling and fixing the top plate. Edited October 9, 2020 by DesignedbyGP 1 Link to comment Share on other sites More sharing options...
GP Modder Posted October 9, 2020 Author Share Posted October 9, 2020 (edited) Top cover profile Edited October 9, 2020 by DesignedbyGP 2 Link to comment Share on other sites More sharing options...
TermudaSquare Posted October 9, 2020 Share Posted October 9, 2020 Coming along nicely bro, can’t wait to see the end result. Well done on the detailed Metal work to make the fitment for the frame pieces. 1 Link to comment Share on other sites More sharing options...
GP Modder Posted October 10, 2020 Author Share Posted October 10, 2020 20 hours ago, TermudaSquare said: Coming along nicely bro, can’t wait to see the end result. Well done on the detailed Metal work to make the fitment for the frame pieces. Thank you, I'm glad you like it. I improvise a lot, the plans change during the construction process. Link to comment Share on other sites More sharing options...
GP Modder Posted October 10, 2020 Author Share Posted October 10, 2020 (edited) Edited October 10, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 10, 2020 Author Share Posted October 10, 2020 (edited) Side glass test ✔ Edited October 10, 2020 by DesignedbyGP Link to comment Share on other sites More sharing options...
GP Modder Posted October 10, 2020 Author Share Posted October 10, 2020 Link to comment Share on other sites More sharing options...
GP Modder Posted October 10, 2020 Author Share Posted October 10, 2020 (edited) Making wooden elements Edited October 10, 2020 by DesignedbyGP 1 Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
