MonsterMawd Posted December 18, 2009 Author Share Posted December 18, 2009 This method can be combined with 4.5" flexible tubing to isolate cool airflow. Imagine one end of the tube attached to a 120mm cooling fan in front of your case. The 4.5" Flexible tubing can be found at Mcmaster, http://www.mcmaster.com/#duct-hose/=4zltce or you can "try" the "Heating & Cooling" department at hardware or home improvement stores like Home Depot or Lowes. Supplies & Tools: 120mm Modder's Mesh Round fan grill, http://www.mnpctech.com/120mm_Custom_FanGrill.html 4.5" fan duct, http://www.mnpctech.com/FanDuct.html 4, #10 x 5/8" fan screws, http://www.mnpctech.com/thumbscrew.html">#10 x 5/8" fan screws 120mm cooling fan. Paint pen or pencil. Tin snips. Wire cutter. 120mm Modder's Mesh Round fan grill, http://www.mnpctech.com/120mm_Custom_FanGrill.html 4.5" fan duct, http://www.mnpctech.com/FanDuct.html Using a paint pen to trace the duct onto the round mesh grill. a small wire cutter and Tin snips used to cut the 4.5" opening in the 120mm Modder's Mesh Round fan grill You'll need to use the small wire cutter first, to make the initial cut before you can use the Tin Snips to cut the 4.5" hole. Using Tin ship to cut the round mesh grill. The result of you cutting should look like this. 120mm cooling fan. This fan has enclosed corners, you will need longer fan screws if you're mounting the fan onto something like a cpu cooler. 4, http://www.mnpctech.com/thumbscrew.html, #10 x 5/8" fan screws Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 19, 2009 Author Share Posted December 19, 2009 We made our version slightly different. Original Prawn canister from District-9 movie Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 20, 2009 Author Share Posted December 20, 2009 Yesterday I painted the 2x 120mm cooling fans from the Cooler Master HYPER N620, will post those photos soon! 140mm Aerocool Fan for the exhaust, was also painted Matte White Fan Grill made from Round Modder's Mesh, http://www.mnpctech.com/moddersmesh.html Link to comment Share on other sites More sharing options...
Biokinesis Posted December 22, 2009 Share Posted December 22, 2009 Loved the movie and so far I'm loving the theme! The bullet holes made by using wire cutters is genius! Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 22, 2009 Author Share Posted December 22, 2009 Thank you! Here is the Prawn canister installed, I've added a 4" White cold cathode light between the front intake plate and bezel. Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 24, 2009 Author Share Posted December 24, 2009 The lighting needs to be dimmed down a bit,for a more eerie looking feel Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 25, 2009 Author Share Posted December 25, 2009 We are going to paint weathered effects on the exterior to make things looks aged a bit. and MERRY CHRISTMAS to all! Link to comment Share on other sites More sharing options...
Maxession Posted December 25, 2009 Share Posted December 25, 2009 It's looking very nice in the dark! Merry xmas! Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 26, 2009 Author Share Posted December 26, 2009 Thank you! Hope you had one as well! Link to comment Share on other sites More sharing options...
MonsterMawd Posted December 27, 2009 Author Share Posted December 27, 2009 The transformation from pristine to weathered and dilapidated. He starts by creating the illusion of a scratched-up exterior, imagine Christopher dragged his computer in the gravel. Did he have to wrestle it away from somebody at one time? The Orange & White exterior finish has been scratched done to the bare metal. This is done by hand using enamel "One Shot" Silver paint and a paint brush. Notice the paint is chipped around the bullet holes. Link to comment Share on other sites More sharing options...
