Jump to content
�O�HotRod��o
ArgOs
  • Replies 41
  • Created
  • Last Reply
Posted
I pop rivets to attach the fender, then I sand it.
my new acquisition, a fan CooleMaster Megaflow.
cut for the wheel.
I prepare the sheet, sanding it.
I put the putty.
paint the front.
Posted
Continuing with my solitary work, Inside the fender, I placed a plate for better viewing and will pass putty for details..
Then I paint with primer.
I pass sandpaper the to the other parts to pass after priming.
The front and the air intake.
I reinforced the top, I will pass the sandpaper and putty, then put the air intake and putty.
I cut to the air intake.
Then I reinforced the bottom and I made ​​some cuts.
And finally I started to paint some parts.
Thanks for your feedback.
Posted
Tortured_soul thank you master.
After the primer was sanded the surface to match it.
Place a plate on her side, and you will see in the future.
Then everything was painted shiny black.
the hinge and silver color foot.
Pictures of the progress of the painting.
I cut the side to match the inclination of the case.
Thanks to all for the comments.
Posted
Thank you master.
The side ready.
I use a part that I cut the case, to create the side support.
I will attach the hinge to the Side. As you will see there is much dust in my garage.
I put a rubber at the foot, between the steel sheet and foot, other rubber will go under.
I created the mesh brackets
I painted pop rivets.
Posted
I hope to finish it takes very little time and I still have not finished the work. :(
Computer hardware.
The Support for HD
I begin to put the hardware in their place.
Other changes in progress. The filter of the air intake.
HR126.jpg:D
Posted
OMG Argos, just like I said, it is soooo hard to see detail on a black mod, specially with a black interior too.
I see the work on the slanted side cover, factory made look like you said. You do need a good wire management job to make us proud. The grill is +1A!
I don't like to rush you but there is just a couple of more days left, so no sleep for you, hehe.
Cheers and Saludos
Posted
Thank you very much PaPang, I'm fighting against time and I will order the wiring.
I will finish it Sunday.
I show you a detail of HD support.
The wheel clock :P
I completely disarmed.
Electronic circuit.
I cut the tires well
and the fan
I cut inside the tire and the fan
Put in place.
  • Create New...
Important Information
