KITSON CHAN Posted May 4, 2011 Share Posted May 4, 2011 大家好! Hello Everyone, æˆ‘æœƒç”¨ä¸æ–‡,英文å°è¯! I will use Chinese, English translation on! 我的英語ä¸å¥½ï¼Œæ‰€ä»¥æˆ‘用谷æŒï¼Œä»¥å¹«åŠ©ç›´æŽ¥ç¿»è¯ï¼ my English is bad, so I use Google to help for direct translation! è«‹å…許我介紹一下自己.我的åå—æ˜¯KITSON CHAN,我ä½åœ¨é¦™æ¸¯. Allow me to introduce myself shortly. My name is KITSON CHAN and I live in HONG KONG. åƒåŠ é¡žåˆ¥:自由創作組 Category: SCRATCH BUILD 主題:熾天使 (由零開始) Topics:SERAPH (scratch build ) æ“šèªªç†¾å¤©ä½¿æœ¬é«”ç„¡å½¢ç„¡è³ªï¼Œä½†å¯æœ‰å¤šç¨®å…·è±¡åŒ–身,是掌管戰鬥的天使,å¤ä»¥è‰²åˆ—戰亂時代的大先知以賽亞曾æè¿°åœ¨ç¥žçš„å¾¡åº§å‰ ç›®æ“Šç†¾å¤©ä½¿çš„ç¶“éŽï¼Œå› 而留下外觀高貴,å†·é…·åŠæ¤å…翼之姿態的傳說。熾天使一çœçœ¼ï¼Œå°±æœƒç™¼å‡ºå¦‚ç…å¼è²ï¼Œä¸¦ç™¼å‡ºç´…色電光劃 éŽé•·ç©ºï¼Œå½¢å¦‚長蛇! Seraph said no body intangible quality, but can be a variety of concrete incarnation is in charge of fighting the angels, the great era of ancient Israel, the prophet Isaiah, the war has been described before the throne of God! Witnessed Seraph through,Thus leaving the appearance of the noble, cold and six wing of the profile of this legend. Blazing a bare-faced, we will send such as Roar sound, and red lightning plan Over the sky, shaped like a snake! 而今次的è¨è¨ˆç†å¿µä¾†è‡ªç†¾å¤©ä½¿: The design concept of this time from Seraph: 1.(外觀):å…翼機箱: 高貴而冷酷,但åˆå¯ä»¥æœ‰å¤šç¨®è®ŠåŒ–,創新è¨è¨ˆç†å¿µ, 變化後機箱有ä¸åŒçš„功能和方便性應用,å°ˆç‚ºè¶…é »çŽ©å®¶èˆ‡DIY玩家所è¨è¨ˆçš„,擺脫傳統機箱的è¨è¨ˆæ¡†æž¶. 1. (appearance): Six-wing case: Noble and cold, but can have a variety of changes, innovative design concepts, After changes in the chassis, it is more user-friendly as it enhances its functions provision and eases the complexity of the application, designed for overclockers and DIY designed player, away from the traditional design of the chassis frame. 2.(強大的戰鬥力)æ•ˆèƒ½å’Œè¦æ ¼: 內部空間è¦åŠƒä¸»æ©Ÿæ¿é¡žåž‹M-ATX / ATX / E-ATX / GIGABYTE XL-ATX,9組擴充槽, 便利性與擴充性大大æå‡,支æŒ4å¼µ(ATI Radeon HD 6870 & NVIDIA GTX 580)é¡¯ç¤ºå¡æœ€å¤§é•·åº¦ç‚º370mm,並安è£é«˜é”3é¡†è¦æ ¼140mm, 4é¡†è¦æ ¼120mm大型風扇和6é¡†è¦æ ¼50mm風扇,1組280水冷排,1組240水冷排,é”到最高散熱 效能,讓玩家å¯ä»¥åœ¨æ—¥å¾Œç¡¬é«”è¦æ ¼å‡ç´šä¸Šæ¯‹éœ€è€ƒæ…®å¤ªå¤š. 2. (strong combat effectiveness) performance and specifications: Interior space planning board type M-ATX / ATX / E-ATX / GIGABYTE XL-ATX, 9 group slot, greatly enhance the convenience and scalability to support four (ATI Radeon HD 6870 & NVIDIA GTX 580) the largest graphics card Length of 370mm, and install up to three standard 140mm, 4 Specifications 120mm large fan and 6 standard 50mm fans, 1 280 water row, 1 set of 240 water-cooling arrangement, the highest heat Performance, allowing the player to upgrade the hardware specifications in the future on the need not think too much. 3.(仿„›çš„心)方便性: è¦ç•«é«˜é”8çµ„çš„ç¡¬ç¢Ÿç†±æ’æ‹”å’Œ2組的DVDç†±æ’æ‹”,å…上螺絲隋æ’å³ç”¨,I/O Panel (USB 2.0 x 2, Audio x 1, Mic x 1, S VIDEO x 1, 1394a x 1, AV x 1, SATA POWER x 2),左崿¿è¨è¨ˆåªé ˆæ”¾ä¸‹ä¾¿æ˜¯LCD MON, 而å³å´æ¿è¨è¨ˆæ”¾ä¸‹å°±å¯ä»¥å¿«é€Ÿæ›´æ›ç¡¬ä»¶,測試硬件和極é™è¶…é »,監控器å¯ç›£æŽ§å„部份溫度和å¯èª¿å¼é¢¨æ‰‡è½‰é€Ÿ,LEDé¡è‰²éš¨å¿ƒæ‰€æ¬²è½‰æ›ï¼Œ æ›´åŠ é«”ç¾çŽ©å®¶çš„é…·ç‚«é¢¨æ ¼èˆ‡å€‹æ€§ç‰é¢å‘,èžåˆéŠæˆ²èˆ‡å¤šåª’體娛樂應用!!!!! 3. (love heart) Convenience: Planning group drives up to 8 hot-swap and group 2 DVD hot-swap, non-Plug and Play on the screws Sui, I / O Panel (USB 2.0 x 2, Audio x 1, Mic x 1, S VIDEO x 1, 1394a x 1, AV x 1, SATA POWER x 2), just down the left side of board design is LCD MON, while the right side of the board design can be quickly put down to replacing hardware, test hardware and overclocking limit, monitor to monitor The part of the temperature and adjustable fan speed, LED color arbitrary conversion, and more reflect the player's cool style and personality-oriented, integrated gaming and multimedia entertainment applications !!!!! Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 計算尺寸,åˆ‡å‰²ææ–™!(Calculated size, cutting material!) 內部尺寸畫線!(Internal dimensions drawing a line!) 剪è£å¤šé¤˜éƒ¨ä»½!(Excess part of the cut!) 用電鑽開å”!(Drill hole!) ç©æ¢³é–‹å”(jigsaw Openings) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 製作出æµé€šç©ºæ°£çš„æ ¼å!(Grid to produce air circulation!) 摺製形狀!(Folding Shapes!) ç„ŠæŽ¥åŠ å›º(Welding reinforcement) 打磨令表é¢å¹³æ»‘!(Polished so that a smooth surface!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 主機æ¿é‡åº¦å°ºå¯¸!(Measure the size of the motherboard!) 電鑽一些å”,給電æºç·šå‡ºå…¥ä½!(Drill some holes, giving the power cord out of place!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 I/O背æ¿å’Œæ°´æ³µé›»æºä½ç½®!(I / O backplane and power supply position of the pump!) PCIæ’æ§½çš„固定架!(PCI slot bracket!) 焊接PCIæ’æ§½çš„固定架!(PCI slot bracket welded!) 測試主機æ¿ä½ç½®(motherboard position the test!) 路軌:機箱背部Iæ’電線時,åªè¦è¼•力拉出機箱! (Tracks: back of the chassis when I plug wires, gently pull out as long as the case!) 門較:使用於打開兩æ—å´æ¿!(Door hinge:Used to open both sides of the side panels!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 測試:安è£å…©æ—å´æ¿!(test:Install both sides of the side panels!) 電鑽一些å”,給電æºç·šå‡ºå…¥ä½!(Drill some holes, giving the power cord out of place!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ç©æ¢³é–‹å”(jigsaw Openings) 打磨!(Grinding!) æ©Ÿç®±é¢æ¿è£½ä½œ!(Chassis panel production!) 摺製形狀:弧形狀!(Folding Shapes: arc-shaped!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ç„ŠæŽ¥åŠ å›º(Welding reinforcement) 打磨令表é¢å¹³æ»‘!(Polished so that a smooth surface!) I/O Panel DIY水冷排(DIY Fin Radiator ) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 焊接:水冷排(Welding:Fin Radiator) é絲擰上æ¿å上,切除éçµ²é ,然後焊接,打磨後,表é¢å°±çœ‹ä¸è¦‹éçµ²é ! (Tighten screws on the board, remove the screw head and welding, grinding, the surface can not see the screw head!) å…©æ—å°¾éƒ¨å´æ¿è£½ä½œ!(Produced on both sides of the rear side panels!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 焊接:å…©æ—å°¾éƒ¨å´æ¿(Welding:Both sides of the rear side panels!) 摺製形狀:å…©æ—ä¸‹éƒ¨å´æ¿å¼§å½¢ç‹€!(Folding Shapes: Both sides of the bottom side arc-shaped!) 支柱架(Pillar framework) 固定支柱架éçµ²(Fixed pillar frame screws) é絲擰上æ¿å上,切除éçµ²é ,然後焊接,打磨後,表é¢å°±çœ‹ä¸è¦‹éçµ²é ! (Tighten screws on the board, remove the screw head and welding, grinding, the surface can not see the screw head!) å°¾éƒ¨æ•£ç†±æ ¼(Tail heat grid) Link to comment Share on other sites More sharing options...
