Jump to content
SERAPH (scratch build )
KITSON CHAN
å®‰è£æ©Ÿç®±é¢æ¿(Chassis panel installation)
COOLER MASTER FAN 140MM X 4 120MM X 4
安è£COOLER MASTER 140MM X2 風扇(installing COOLER MASTER 140MM X2 FAN)
溫度和風扇監控器(Temperature and fan monitor)
I/O Panel
Link to comment
  • Replies 112
  • Created
  • Last Reply
將所有電線隱è—åœ¨æ©Ÿç®±é¢æ¿çš„æ§½å…§(All wires hidden in the chassis slot panel)
安è£äºžåŠ åŠ›è† æ©Ÿç®±é¢æ¿(Acrylic Chassis panel installation)
安è£éš”塵é‹é¢æ¿(Aluminum panels installed)
InstallDVD Panel
DVDç†±æ’æ‹”,å…上螺絲隋æ’å³ç”¨,åªè¦æŽ¨å…¥ä¾¿å¯ä»¥!(DVD hot-swappable, Plug-free screw Sui!)
Link to comment
H.D 啟動時LED便亮起!(LED lights up when it starts H.D!)
安è£I/O Panelé–€(Installing I / O Panel Door)
安è£8組H.Dç†±æ’æ‹”,å…上螺絲隋æ’å³ç”¨(8 groups H.D installed hot-swappable, Plug-free screw Sui)
安è£ä¸éŠ¹é‹¼æ‰‹æŠ½(Installing Stainless steel hand Handle)
Link to comment
安è£:å·¦å³é–€(Installation: left and right doors)
安è£:機箱頂部(Installation: Chassis top)
安è£è† åœˆ (Installation rubber gasket )
安è£é–€è¼ƒ:使用於打開兩æ—å´æ¿!(Installation door hinge:Used to open both sides of the side panels!)
Link to comment
9組擴充槽:手扭螺絲(9 expansion slots group: hand twist screws)
安è£COOLER MASTER 風扇(COOLER MASTER fan installation)
120MM X 2 風扇罩(120MM X 2 fan cover)
Link to comment
å®‰è£æ°´ç®±(Installing Reservoir)
底æ¿èƒŒéƒ¨çš„COOLER MASTER 140MM 風扇,令底æ¿èƒŒéƒ¨æœ‰æ›´å¥½æ•£ç†±æ•ˆèƒ½
(Motherboard COOLER MASTER 140MM fan on the back of the motherboard back, better heat removal!)
å®‰è£æ°´æ³µ(Installation of pumps)
安è£å°¾éƒ¨æ•£ç†±æ ¼(Install rear cooling grid)
安è£:下方左å³é–€(Installation: the bottom of the portal)
Link to comment
安è£:下部散熱格!(Installation: lower cooling grid!)
測試POWER,RESET制(Test POWER, RESET )
安è£å·¦å³å…©æ—æ¿çš„é–€(Left and right sides of the door panel installation)
å®‰è£æ°´æ³µåˆ¶,å¯ä»¥ä¸ç”¨é–‹å‹•電腦,åªé ˆæŒ‰æ¸¬è©¦åˆ¶ä¾¿å¯ä»¥æ¸¬è©¦æ°´å†·ç³»çµ±!
(Installation reply, do not have to start the computer, simply press the test button to test the cooling system can be!)
Link to comment
  • Create New...
Important Information
