KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 2組隋æ’10MMå’€,入水,æŽ’æ°´æˆ–å¤–åŠ æ°´å†·ç³»çµ±éƒ½éžå¸¸æ–¹ä¾¿ (Group 2 10MM Tsui Sui inserted, into the water, drainage or external water cooling systems are very convenient) 安è£LED燈æ¢(LED Light Installation) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ç„ŠæŽ¥å’Œéš±è—æ‰€æœ‰ç·šè·¯(Welding and hide all the cables ) å®‰è£æ°´ç®¡(Installation of water pipes) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 安è£COOLER MASTER 1000W é›»æºå™¨(COOLER MASTER 1000W power supply installed) å®‰è£æº«åº¦ç›£æŽ§ç·šå’Œæ°´å†·ç³»çµ±(Install temperature monitoring cables and water cooling system) 製作å°åž‹æ•£ç†±é¢¨æ‰‡æž¶(Production of small cooling fan rack) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 示範:機箱背部Iæ’電線時,åªè¦è¼•力拉出機箱! (Demonstration: back of the chassis when I plug wires, gently pull out as long as the case!) 示範:8組 H.Dç†±æ’æ‹”,å…上螺絲隋æ’å³ç”¨,åªè¦è¼•鬆æ’入便å¯ä½¿ç”¨! (Demonstration:8 groups H.D hot, non-Plug and Play on the screws Sui) 監控器åªè¦ä¸€æŒ‰éµ,便å¯è½‰æ›LED燈é¡è‰²(Monitor button, LED light color can be converted) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ä¸åŒè§’度觀賞!!!!(Different angle viewing!!!!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ä¸åŒè§’度觀賞!!!!(Different angle viewing!!!!) 打開å³å´æ¿å°±å¯ä»¥å¿«é€Ÿæ›´æ›ç¡¬ä»¶,測試硬件和極é™è¶…é » (Open the right side of the board to quickly replace hardware, test hardware and the ultimate overclocking) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ä¸åŒè§’度觀賞!!!!(Different angle viewing!!!!) 打開下方門(Open the bottom door) 按一下彈出支柱(Click the pop-up pillars) (3)æ‹‰é–‹å·¦å´æ¿(Opened the left side panel) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 LCD MON掀起便å¯ä»¥ä½¿ç”¨(Open the can use the LCD MON) 打開å³å´æ¿å°±å¯ä»¥å¿«é€Ÿæ›´æ›ç¡¬ä»¶,測試硬件和極é™è¶…é »! (Open the right side of the board to quickly replace hardware, test hardware and the ultimate overclocking!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 6, 2011 Author Share Posted May 6, 2011 ä¸åŒè§’度觀賞!!!!(Different angle viewing!!!!) Link to comment Share on other sites More sharing options...
