KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 磨髮絲紋(Hairline grinding) 焊接:å°¾éƒ¨æ•£ç†±æ ¼(Welding:Tail heat grid) å°¾éƒ¨æ•£ç†±æ ¼å®Œæˆ(Completion of the tail heat grid) 製作ä¸åŒå°ºå¯¸ä¸éŠ¹é‹¼ç·šæ§½(Produce different sizes of stainless steel trough) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 製作ä¸åŒå°ºå¯¸ä¸éŠ¹é‹¼ç·šæ§½(Produce different sizes of stainless steel trough) 安è£ä¸éŠ¹é‹¼ç·šæ§½(Installation of stainless steel trough) 擺放8組硬碟的ä½ç½®!(8 groups placed the location of the hard disk!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 æ”¹é€ æ°´ç®±(Transformation of the water tank) DIYä¸éŠ¹é‹¼æ‰‹æŸ„(DIY Stainless steel hand Handle) 製作:æ©Ÿç®±é ‚éƒ¨( production:Chassis Top) é絲擰上æ¿å上(Tighten screws on the board) 切除éçµ²é ,然後焊接,打磨後,表é¢å°±çœ‹ä¸è¦‹éçµ²é ! (Head screws removed, and then welding, grinding, the surface to see screw head!) é ‚éƒ¨ä¸éŠ¹é‹¼ç¶²(Top of the stainless steel mesh) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 鑽å”水管通é“(Drilling water channel) 製作:DVD SATA熱æ’拔架(Production:DVD SATA hot-swap Frame) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 製作:äºžåŠ åŠ›è† æ©Ÿç®±é¢æ¿(Production: Acrylic Chassis panel) 鑽å”(Drill holes) ç©æ¢³é–‹å”(jigsaw Openings) 打磨!(Grinding!) 製作:é‹é¢æ¿(Production:Aluminum panel) 畫圖(Paint) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 監控器é¢æ¿ä½(Monitor panels position) ç©æ¢³é–‹å”(jigsaw Openings) 打磨!(Grinding!) ä¸è¦éƒ¨ä»½åˆ‡é™¤!(Not part of the cut!) 120MM X 2 風扇罩(120MM X 2 FAN Cover) 摺製形狀!(Folding Shapes!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 I/O Panelé–€(I/O Panel DOOR) é ‚éƒ¨è£é£¾(Top decoration) 製作:DVD罩(Production:DVD Cover) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 磨髮絲紋(Hairline grinding) POWER,RESET固定架(POWER,RESET fixation) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 POWER,RESET架(POWER,RESET Frame) 摺製形狀!(Folding Shapes!) POWER,RESET固定架é‡åº¦ä½ç½®!(POWER, RESET fixation measurement location!) 安è£POWER,RESET固定架(Install POWER, RESET fixation) 120MM X 2 風扇罩(120MM X 2 FAN Cover) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 å·¦å³å…©æ—æ¿çš„門畫圖案!(Left and right sides of the door panels painted designs!) å·¦å³å´é–€æ‰‹æŸ„(Left and right side door Handle) 鑽å”(Drill holes) ç©æ¢³é–‹å”(jigsaw Openings) 打磨!(Grinding!) Link to comment Share on other sites More sharing options...
