Jim Weist Posted May 27, 2014 Author Share Posted May 27, 2014 The last thing I want to show you really quick is the interior mid plate bulkhead placement, I was going to drill and mount them but I want to wait until I have the corresponding piece of hardware to line up the fittings as close to perfect as possible. I think its going to look pretty amazing, you can get the idea if you use a little imagination =D Well guys I tried to load this update with photos for you since I had a delay between posts, I hope you enjoyed the update! Should have another juicy update for you in a little over a week. Oh yeah dont forget to check out my page Clockwerk Case Mods to get daily photos of whats going on in the workshop! Thanks again for checking out the build, take care for now =D Link to comment Share on other sites More sharing options...
Jim Weist Posted June 9, 2014 Author Share Posted June 9, 2014 Hey guys! I managed to start my custom reservoirs going. Im starting trim on the top one and I think I am going to redo the bottom one as one of the seams did not glue solid and I am having some leaks. I have also been busy with the CNC, its almost finished now, just need the spindle and some odds and ends. Once its done I can put my money towards buying the rest of the components for this build. Anyway on to the update! Hope you guys enjoy it! First thing is that I greatly appreciate the help from my sponsors, they are the foundation of this project! Here we go! I got my motherboard tray locked in place now with some aluminum cubes. I also went through and started removing the rivets and replacing them with rivet nuts so the case will no be assembled with screws rather than rivets. It makes things much cleaner and easier to break down and assemble. Next up I modded the bottom case bezel to hold two bulkheads and a little window to the bottom res. Two tubes will go from the top res and bring water down to the bottom res. I used the step drill to cut the holes out. Link to comment Share on other sites More sharing options...
Jim Weist Posted June 9, 2014 Author Share Posted June 9, 2014 Then cleaned them up with the dremel and put in the bulkheads. Next I cut out a window, I am not sure what trim to go with yet, white or copper. I might actually make acrylic trim for a more professional look. Now Ill show you the top reservoir. I am leaving the bottom res out because I am most likely going to remake it. Its only about 20$ in acrylic per reservoir without the trim. So I got the acrylic and some more syringes and a new needle from McMaster. Link to comment Share on other sites More sharing options...
Jim Weist Posted June 9, 2014 Author Share Posted June 9, 2014 I took the acrylic and cut it down to the correct sizes and made rabbit joints on the ends to make them more leak resistant when I glue them. I cut grooves in the mid plate that the water will flow over to hopefully keep the water a little more even. Link to comment Share on other sites More sharing options...
Jim Weist Posted June 9, 2014 Author Share Posted June 9, 2014 After all the panels were cut and rabbited I got to work getting the fittings in place. After drilling it was time to tap the front fitting holes. A good trick is to run the tap through a block of wood then into the acrylic. It keeps the tap straight and prevents cracking of the acrylic. Once the front were on I did the back return and top fill fitting. Quick set in place to get an idea of it, and then lay everything out to glue. Link to comment Share on other sites More sharing options...
Jim Weist Posted June 9, 2014 Author Share Posted June 9, 2014 This res glued together rather well. Final res without the trim. Filled it with some liquid and let it sit over night. It passed the test. Link to comment Share on other sites More sharing options...
Jim Weist Posted June 9, 2014 Author Share Posted June 9, 2014 Even if it leaked a little the trim will block all the seams with another layer of reinforcement. Here is the first trim panel I set up. I am bringing it up and around the fittings on all panels of both reservoirs. The trim will also be masked off and painted copper once glued on for a white-copper-white-copper contrast. Here is the trim in its glory. I am going to glue it square to the bottom right and flush cut the overhang. Then get it done. Well thats what I have for now. Hope you enjoyed it! Always love some feedback! I plan to have both reservoirs trimmed, mounted and connected for the next update. There are only a few things left that I can do before installing hardware, its finally getting to that point!! The CNC was eating my funds but after this friday I will be able to spend money on components. I already have my hardware decided and water loop as well. If you want to stay up to date on my progress daily check out my modding page Clockwerk Case Mods. Until next time modders!! Link to comment Share on other sites More sharing options...
Jim Weist Posted June 24, 2014 Author Share Posted June 24, 2014 Hey everybody! I got a whole lot of update here today! Hope you all enjoy! I have a ton of photos so lets get right into it! First and foremost thanks to my awesome sponsors! You guys are truly amazing!! Alright first thing I got some more parts in. Mod/smart sent me in the power and reset switches along with spools and spools and spools of PSU pins for sleeving my own cables!! I am now stocked and I love it! I recently had inquiries to make custom handmade reservoirs for some peoples builds after sharing pictures of mine. So I picked up a new 15/32 plastic drillng bit and a new syringe. These larger syringes are the way to go, they don't jam up and explode solvent everywhere. Alright some modding! I painted the connectors needed to get my power supply sleeved, I hope to get that sleeved for next update. Speaking of sleeving I found this paracord online and the color is called rust, it is really really close to the metallic copper. I think I will use it for some accent striped between the white. Link to comment Share on other sites More sharing options...
Jim Weist Posted June 24, 2014 Author Share Posted June 24, 2014 Alright now into the reservoir work, there is quite a bit of it =D First up was finishing the bottom reservoir. First cut all the pieces the drill and tap what needed to be, then glue together. Then fit it together, glue it, and leak test it. This one is much better than my first. I had a dulling router bit and it was just a crap finish the first time, I didn't even share it. This one glued up mint with no leaks! Next up was trimming both reservoirs. I have tons of photos as I shared every day but I am going to kind of broaden it out so my update doesn't have 150 photos of me cutting on the scroll saw haha Link to comment Share on other sites More sharing options...
Jim Weist Posted June 24, 2014 Author Share Posted June 24, 2014 When I cut the trim I would do one axis at a time and flush cut the trim even with the edge on my router table. After all the trim was on I was really happy with the way it came out! In the next update I should have the trim painted and installed correctly. Next up was mounting the reservoirs. The top res is fastened to he motherboard tray and the bottom one is now flush with the front face of the bezel after some modding =D. I have to attach it with a screw or 2 when I have it exact. The bottom bezel will get some more detail treatment eventually. Link to comment Share on other sites More sharing options...
