ne(V)esis Posted August 8, 2012 Share Posted August 8, 2012 Done, I've registered into the contest! Hope this year the competition will be harder and see marvelous mods from the people around the world! I will do my best, so good luck to everybody! ne(V)esis Link to comment Share on other sites More sharing options...
Ianovski Posted August 8, 2012 Share Posted August 8, 2012 Signed myself up! Last year i couldn't participate because my mod was before the asked time. Now I can Thanks to Cooler Master for this competition and good luck to everyone! Link to comment Share on other sites More sharing options...
CM_modder Posted August 9, 2012 Share Posted August 9, 2012 Hey CM, Great to see this contest back again !!!One small question ... What is a Cooler Mod? Only CM hardware ? Built by CM employees ? or ... ??? I'm fairly sure it's just a case mod that's made using a Cooler Master case. Will check this and get back to you! Link to comment Share on other sites More sharing options...
Mpovh Posted August 9, 2012 Share Posted August 9, 2012 For the “Tower Mod†category, you can use any chassis (full, mid, M-ATX or M-ITX) made by Cooler Master.For the “Scratch Build†category: The case you use could be built from any material you like If you choose to use a prefabricated case, please use the following guide lines: No display of any manufactures logo. Final product must not be recognizable compared to its original design. At least (1) Cooler Master product must be included in the mod For the “Cooler Mod†category, you can use any Cooler Master cooler. Yes, need a CM case =P Link to comment Share on other sites More sharing options...
Peter Brands Posted August 10, 2012 Share Posted August 10, 2012 I though it would never start Go go go! Post those awesome buildlogs Link to comment Share on other sites More sharing options...
Boddaker Posted August 10, 2012 Share Posted August 10, 2012 I though it would never start Go go go! Post those awesome buildlogs You entering again Peter? Link to comment Share on other sites More sharing options...
Peter Brands Posted August 10, 2012 Share Posted August 10, 2012 My current and coming mod don't apply to the rules. But that´s no problem Link to comment Share on other sites More sharing options...
Jeffrey Stephenson Posted August 11, 2012 Share Posted August 11, 2012 @slipperskip We will look into moving the original April cut-off back a bit, will keep everyone posted! Thanks for the suggestion.Apparently the rules are The project can have started anytime as long as it was finished after April 2012". Is that right? Maciel Barreto was disqualified last year for not having his dates right. It is still very confusing why that happened especially at the last minute in the contest.I'm covered either way. I have a project I started in April 2012 if I decide to use it. I'd just hate to see another tragedy like what happened to Maciel. Thanks. Link to comment Share on other sites More sharing options...
ASPHIAX Posted August 11, 2012 Share Posted August 11, 2012 I am covered too fortunately ! I took it to a LAN party at april 7th as-is (I fried a mobo, CPU and GPU 2 days before) and had to do a lot of work afterwards to restore it completely. Now preparing for one of the hardest jobs, deciding how to airbrush the AT-AT. As I am new to airbrushing that will be a major challenge ! Link to comment Share on other sites More sharing options...
Jeffrey Stephenson Posted August 11, 2012 Share Posted August 11, 2012 The rule might be that you can't have started your project before April. That would disqualify you right?. I'm pretty sure that is what disqualified Maciel last year. The rule says, cut and pasted..... Your mod must NOT be earlier than April 2012. Not started earlier or not finished earlier? Link to comment Share on other sites More sharing options...
