knghtbrd Posted September 12, 2005 Share Posted September 12, 2005 Now that you mention it and I look closer, you're right. That video card is massive. As I'll be using nF4, I'm a bit concerned about cooling it. I'll probably be using an ASUS board, either the Deluxe or Premium version. I like the passive heatpipe cooler on the Premium, but that may be the wrong northbridge cooling setup to use with a single 80mm exhaust fan. Swapping one PCIe 1x for a 4x and the replacement of an active northbridge cooler for a passive one seems to be all that differs from the two, and the 4x slot is likely to be blocked by anything sane on your video card anyway.. Link to comment Share on other sites More sharing options...
Guest Mindless Moron Posted September 12, 2005 Share Posted September 12, 2005 i'm going for the DFI, im getting BH5 ram and its the best one for it. Link to comment Share on other sites More sharing options...
knghtbrd Posted September 12, 2005 Share Posted September 12, 2005 They tell me the ASUS is the stability board and the DFI is the overclocker board. I tend to replace my hardware too often to worry about overclocking it. Link to comment Share on other sites More sharing options...
_ferry_ Posted September 12, 2005 Author Share Posted September 12, 2005 The only thing about the epox board witch could be better IMHO is the Vmem, it goes to 3,1v. Not enough for my BH5. But the functions are nice, like the status led's and a VU-meter. The chipset cooler is good, it doesn't produce much noise, but there isn't enough space for a blue ice for example. Link to comment Share on other sites More sharing options...
sherren Posted October 24, 2005 Share Posted October 24, 2005 Nice Project there you have ferry You using 2 PSU right?how did u made it into one connector where u conenct it to an adapter to ur psu the black wire Link to comment Share on other sites More sharing options...
_ferry_ Posted November 20, 2005 Author Share Posted November 20, 2005 Sorry for the late reply, bit the primary PSU is switching a relay. When that relay is closed, the 2'nd PSU will be powered uo. There is also a switch parralel over the relay so the 2'nd PSu can be powered up without powering up the primary one. The 2'n is only for lights and fan's. Link to comment Share on other sites More sharing options...
pricek Posted November 29, 2005 Share Posted November 29, 2005 Looks good.. whats those uv blue individual cables? Link to comment Share on other sites More sharing options...
Tiny Tim518 Posted November 29, 2005 Share Posted November 29, 2005 amazing Link to comment Share on other sites More sharing options...
_ferry_ Posted December 4, 2005 Author Share Posted December 4, 2005 Looks good.. whats those uv blue individual cables? Bought them somewhere at a hardware show, but might A.C. Ryan should be able to supply them, not 100% shure. I used them for the ATX powerconnector, still want to do the same with the 4pin power connector. BTW, Coolermaster casemod contest is almost done, so within a few weeks i hope to post new updates. Link to comment Share on other sites More sharing options...
Amodedude1 Posted December 28, 2005 Share Posted December 28, 2005 I haven’t counted yet but i could almost bet you've been awed over a 1000 times. so here goes #1001 Dude thats super sweet man! Link to comment Share on other sites More sharing options...
