_ferry_ Posted August 16, 2005 Author Posted August 16, 2005 So when do you start taking orders _ferry_? I already did 1, and more to come, if i have some time for it Anyway, here is an update, someone gave a idea of mounting some plexi beyond the air intake covers on the sidepanels. So i tried: Later i also mounted a 10cm CCFL, i don't know exactly how to explain the way i've mounted it, but i had to cut the normal CCFL pipe in half to be small enough. 5 candyshots I had to mount the 3 plexi pieces at the front permanent and correctly aligned ( some of them were cracked, so i made new ones) And might add some black paper on the back, to prevent seeing the CCFL mirrored in the window
ID Posted August 16, 2005 Posted August 16, 2005 Jum jum I completely agree............. So ferry, is the end in sight? It's amazing how much work you've put into this case. Is it an ongoing thing, or do you definitely know when you'll be done?
_ferry_ Posted August 17, 2005 Author Posted August 17, 2005 well, i think the case himself will be done in 2 months. Depens of the problem with the reservoir. But then i want to build the spider on the right side and a tft monitor witch fit the theme.
Death_Korps Posted August 21, 2005 Posted August 21, 2005 Dude i know you may have been praised to heaven about your case but that is seriously some hardcore modding 20/10 dude,, 1 small question though, when painting the chassis black how did you do it? did you sand before hand ? any help would be great as i would really like a black interior on my stacker which im ordering tommorow
Guest Mindless Moron Posted August 21, 2005 Posted August 21, 2005 look for a multipage by Dark-Rain mate, got all the information you need.
Death_Korps Posted August 22, 2005 Posted August 22, 2005 cheers dude, does anyone know if there is a place in the uk where you can get replacement panels for the stacker as i want to btx style it by flipping the mobo over and then have a windowed right side panel
ID Posted August 22, 2005 Posted August 22, 2005 cheers dude, does anyone know if there is a place in the uk where you can get replacement panels for the stacker as i want to btx style it by flipping the mobo over and then have a windowed right side panel Why don't you start another thread for this. This is ferry's worklog.
