SotosLg Posted February 16, 2017 Author Share Posted February 16, 2017 It is getting along really nice for a 1st pass!! More will be applied later on today!! Here are the leftovers of the putty than went through the grill. Before assembly they will be trimmed. Link to comment Share on other sites More sharing options...
SotosLg Posted February 17, 2017 Author Share Posted February 17, 2017 Here we are again! Today i thought i should paint the effect a bit to see how it would turn out later on after i apply the rusting effect on it. So, at first, i applied a thick layer of primer. Remember, nothing will remain like this! After it dried out, i took a paintbrush and sprayed the tip with ruby red and painted the effect. It turned out irrelevant to what i wanted, so next i cleaned the brush with nitro thinner and took an old spray cap and mixed some black matt and that color and it turned out like this! Next what i did, was take the paintbrush and gently apply it to the effect using the sponge/pinch technique. What happened next was this, the color appeared better than i thought! From now on, i thought i try the pinch/sponge technique the panel. Not bad result! Next i tried the paint splash using....my finger with that ruby red color! More effect will be applied later on today or maybe tomorrow! Link to comment Share on other sites More sharing options...
SotosLg Posted February 17, 2017 Author Share Posted February 17, 2017 Quick update!! A few minutes ago, my partner sent me an email with the end product, the game logo finally 3d printed and ready to be sent to me!! I am very happy and satisfied with the result!! I can't wait to take it into my hands!! Link to comment Share on other sites More sharing options...
Alex Ftoulis Posted February 18, 2017 Share Posted February 18, 2017 Really nice start and good luck with the rest! Instead of applying that much isopon and waste it is better to use some fiberglass paste and only a thin layer just my 2 cents! Good luck buddy do your best Link to comment Share on other sites More sharing options...
SotosLg Posted February 18, 2017 Author Share Posted February 18, 2017 27 minutes ago, Alex Ftoulis said: Really nice start and good luck with the rest! Instead of applying that much isopon and waste it is better to use some fiberglass paste and only a thin layer just my 2 cents! Good luck buddy do your best Thank you Alex, it's really important for me that you commented!! Really nice idea, I might add a glassy melted effect!! Peace brother!! Link to comment Share on other sites More sharing options...
SotosLg Posted February 18, 2017 Author Share Posted February 18, 2017 Today I got a package from my partner and and it contains all of what I ordered!! The logo will be applied in Monday!! Tomorrow I have work to do to the other side panel!! Link to comment Share on other sites More sharing options...
Alex Ftoulis Posted February 19, 2017 Share Posted February 19, 2017 Yay goodies Always nice to have packages arriving ! Link to comment Share on other sites More sharing options...
SotosLg Posted February 19, 2017 Author Share Posted February 19, 2017 1 minute ago, Alex Ftoulis said: Yay goodies Always nice to have packages arriving ! You know how it works! Always a pleasure getting something you planned for something great! Link to comment Share on other sites More sharing options...
SotosLg Posted February 20, 2017 Author Share Posted February 20, 2017 Hello again!! A few hours ago, i ordered this beauty, the dremel moto saw which i want it to make the 2 and the lamda out of acrylic pieces. So, for now, lets focus on the other side panel and make that scorched effect!! Link to comment Share on other sites More sharing options...
SotosLg Posted February 20, 2017 Author Share Posted February 20, 2017 Not bad for a 1st pass!! Link to comment Share on other sites More sharing options...
