C0LLARD Posted August 10, 2022 Author Share Posted August 10, 2022 Lantern : Ring lid it! First lightning test here: Link to comment Share on other sites More sharing options...
C0LLARD Posted August 10, 2022 Author Share Posted August 10, 2022 On 8/3/2022 at 7:08 AM, E x e said: I like this already Thank you E x e ! 1 Link to comment Share on other sites More sharing options...
C0LLARD Posted August 25, 2022 Author Share Posted August 25, 2022 Mobo/GPU bracket : Hand made it! I know CNC machines are made for that, but I dont have access to any CNC or 3D printer. I had to make the acrylic bracket using hand tool. It was a lot of work but the result is pretty good anyway. I modified this ASUS small blower to have a minimum airflow in this closed section: Then, painted black the bracket: Mobo/GPU bracket done: Link to comment Share on other sites More sharing options...
C0LLARD Posted August 27, 2022 Author Share Posted August 27, 2022 Mobo/GPU bracket : mobo on! Budget cut and canot buy the computer parts (excep for the GPU). So, I dissasembled last year Liz Art Lab build for parts: - ASUS rog strix Z390i with EK monoblock - Cooling its Intel i5 9600k - With 16g DDR4 3200mhz Trident Z RGB - And 1To Samsung 970 EVO Plus Now, lets fit it on the bracket : Link to comment Share on other sites More sharing options...
C0LLARD Posted September 2, 2022 Author Share Posted September 2, 2022 Mobo/GPU bracket : GPU on! For the GPU, I had the opportunity to get this RTX 3080 Founder + EK block from a friend : To make a solid enought holder for, I used 3 of this power cord bracket from old Panasonic plasma TVs: I modded and installed them: Wonderfull ! This heavy beast is nicely hold: Link to comment Share on other sites More sharing options...
C0LLARD Posted September 2, 2022 Author Share Posted September 2, 2022 (edited) Mobo/GPU bracket : Fittings, tubings and cable management. I really enjoyed this part of the assembling. This is where every details matter and everything on that bracket will be apparent. I spend easily ten hours of pure fun on that. Here's the result : Next step: testing... Edited September 4, 2022 by C0LLARD Link to comment Share on other sites More sharing options...
C0LLARD Posted September 4, 2022 Author Share Posted September 4, 2022 Mobo/GPU bracket : testing Now, lets see if everything works: Oh yeah ! It work perfecly and I am impressed by the power of this GPU. 2 Link to comment Share on other sites More sharing options...
Keir Graham Posted September 22, 2022 Share Posted September 22, 2022 That is a great use for an old heater, and you get a awesome custom radiator out of it too, looks very cool. What where the temps you got out of it? Link to comment Share on other sites More sharing options...
Guest HarveySig Posted September 22, 2022 Share Posted September 22, 2022 Элита сериалы онлайн шара в течение добром качестве? Так яко все так-таки вы пришли по адресу! Точно здесь ваша милость сможете всматриваться онлайн телесериалы на российском языке. Энный сезон, все серии подряд. На религия хоть улучить преферанс, новшества, легендарные, любимые турецкие сериалы онлайн сверху русском. В огромном каталоге сериалов он-лайн с удобной навигацией дозволяет подобрать телесериалы предначертанною тематики. Лучшие телесериалы чтобы просмотра он-лайн в течение жанре мелодрамы, несчастья, сыщика, исторической злополучия, комедии, триллеры, молодежное кино. По всем статьям хоть отхерачить свои запросы а также он-лайн посмотреть телесериалы субподряд в течение согласовании с личными вкусовыми предпочтениями – штучно, вместе с излюбленным дядей или ну ясно как день тет-а-тет вместе с друзьями. Традиция подсчет, что унше всех без исключения сериалы обозревают онлайн бесплатно. Для настоящего целесообразно использовать в своих интересах нашим сервисом. Наши новинки: лучшие сериалы: https://proserial.org/drama/2678-polet-pticy-2022.html сериал лучшие смотреть онлайн все серии: https://proserial.org/drama/2672-pistolet-2022.html сериал онлайн бесплатно серии: https://proserial.org/drama/2560-besstyzhie-2011.html смотреть онлайн сериалы качестве: https://proserial.org/uzhasy/1188-s-toboj-v-den-konca-sveta-2021.html сериалы онлайн подряд: https://proserial.org/istoricheskie/2499-vysshee-2021.html [url=http://www2s.biglobe.ne.jp/%7EAkiko/bbs/index.html]смотреть онлайн сер[/url] [url=http://stabosepo.altervista.org/cms/index.php/component/kide/]лучшие сериалы[/url] [url=http://ceedclub.ru/forums/index.php/topic,1982.new.html#new]лучшие сериалы[/url] [url=https://thasao-kan.go.th/webboard/index.php?topic=22738.new#new]смотреть онлайн сериалы качестве[/url] [url=http://o98065hq.bget.ru/index.php?topic=67371.new#new]сериалы онлайн все серии подряд[/url] e01_2f6 Link to comment Share on other sites More sharing options...
C0LLARD Posted September 24, 2022 Author Share Posted September 24, 2022 On 9/22/2022 at 5:05 PM, Keir Graham said: That is a great use for an old heater, and you get a awesome custom radiator out of it too, looks very cool. What where the temps you got out of it? Thanks Keir! I didn't test it long enought to see the temps. In fact, I was looking for any serious issue, I didn't bother about the temps. But I can say for sure that this 230mm fan inside HOPE work very well. It push a decent airflow through those rads. I will update about the temps on the final testing. Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
