Jump to content
Hope Lantern
C0LLARD
 Share
Pictures : top section and PC off
GPU block side, lit with a 6" LED ring from left at ~ 2m:
Same with mobo side:
Mobo again, lit from behind:
And then, lit from top:20221212_094442.thumb.jpg.9064ab67444831f4ef3f6d6aff0b8d10.jpg
GPU side, lit from the bottom white LED ring on the base:
Link to comment
Pictures : moving out
The plan is to go outside with the build to see if I can take good pictures near the forest.
Before that, I took those last shots:
Then, the Cooler Master MasterFan 200mm ARGB :
I modified a 16mm tube to connect with the fountain pipe inside the globe. This way, I can use Hope Lantern's pumps to remove the liquids in the globe:
Time to go outside:
Battery power bank, water and kit for photos, I have everything :
I like those trees :
Time to fill it with water only. I will not use oil for this session because I am nervous about the extra weight and it needs 3 more step to empty it.
2x speed filling video :
2x speed running test video :
Now, let see if I can take few good shots.
Edited by C0LLARD
Added picture
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
 Share
  • Create New...
Important Information
