Longhorn1000 Posted May 12, 2011 Author Share Posted May 12, 2011 Ok, so here's the update This afternoon, went to a local hardware shop and bought.......what are these called in english? decided to stick them overlapped like this with hot glue done so, we are gonna leave this aside for now this is the original position of the acrylic and this is the new position how bout this? I'll figure it out tomorrow. so I decided to make a center piece today 3cm in width...dunno the length yet there we go, 1 down, 3 to go em.bonus XD lol here is a piece of metal bezel with huge holes and a roll of aluminum bezel, with small holes on the big side decided to cut it till it fits the middle hole first piece Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 12, 2011 Author Share Posted May 12, 2011 nicely fitted mark the hypotenuse and cut it out fits nicely now time for the aluminum cut out a long piece... first transmission failure........... recovering in a few XD Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 12, 2011 Author Share Posted May 12, 2011 transmission recovered........... note, this is at night so = not so good lighting cut the piece to fit the holes next aha, let's get the painting party started from left to right grey( base ), matte black ( first/second coating), yellow ( final coating ) base done second and first and second coat done I painted each coat in a 5-7 minutes interval first and second coat complete as you can see, I'm sticking tapes on it to make patterns and when you see the results, it might be a little nasty as I wanna create a scuffed and old effect using the yellow paint done............now I have to wait for a long time...... stay tuned guys, the final results will be up soon Transmission complete...... Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 12, 2011 Author Share Posted May 12, 2011 Ooooohhhh here it comes can't wait to see the end results....... Ahhhhhhhh.........looks like a charm wow, never thought of being that nice.... so here are the end results.......hope you enjoy this update of mine. Be sure to check out tomorrow and saturday as these are the 2 last days for me to complete the job Don't miss it!!! Hmm.......I suddenly felt like Chef Robert Ervine in Dinner Impossible lol :lachen: Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 13, 2011 Author Share Posted May 13, 2011 Ugh..... Finally, updates so here's one of the parts........ A piece of cardboard make it 2 decided to stick the long piece onto the base with tapes for now align the cards to the side This may not be the most accurate measurement of all time but, trust me, it works sorry E4, it seems that I may need to use you first drew out the sketched side cut it there's a hole !! O_O don't worry about a thing, the glue will do the rest stick it to the sides but will it fit the long piece of acrylic Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 13, 2011 Author Share Posted May 13, 2011 fits ;D probably one of the hardest step......making them stick together in an angle done new one sand it had to put some weigh as the big piece kept tilting upwards looks badass the other side next side an hour later.......I had to get some glue as the hot glue gum finished time for some paint job and again, the base ( interior ) first coat ( matte black ) outer coat done ok then....this is for today... C ya and stay tuned tomorrow Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 14, 2011 Author Share Posted May 14, 2011 wOOT !! uPDATES here's the piece of bezel twist off the scary sides cut it into 3 parts same thing with the other piece I'm a JSF-35C fan anyways, the 2 painted sides from yesterday thanks to Bill Owen on Mnpctech, I now don't need to buy carbonfiber sheets, just paint them. You can search for it on youtube Mod Men Episode 2 done, now just have to wait in the mean time, I'm gonna concentrate back onto the case itself woot! I said lego.....here's lego Bionicle Toa Mahri sets Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 14, 2011 Author Share Posted May 14, 2011 but how am I gonna fit both of them together?? easy, cut 1/4 of the box on each of them the saw!!!:devil-smi measure the back end roughly about 19.5 cm.........not the most accurate measurements but it will do 9.6/7 cm on the box which is needed to be cut off mark it and cut it there we go same with the other side will it fit?? that's the last prob at least 10 minutes passed..... wow, looks great hmm...a hole in the pipes?? cut those small pieces off and hope that they can fit lets glue it up Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 14, 2011 Author Share Posted May 14, 2011 sand it....... fits glued up and looking good continued work... sand the sides of the box cut off excess glue drips and ready for painting letting it dry up...... meanwhile......the pvc pipes are finally back a piece of unused acrylic sand it and glue it and yes, apply the glue to the pipes as well done sticking and let it rest until the glue are dried up final part the coat is dried up and ready for more detailed coats Link to comment Share on other sites More sharing options...
Longhorn1000 Posted May 14, 2011 Author Share Posted May 14, 2011 the side done..... now for the interior painting the side doesn't look that great compared to the top though.... ok, more pics in one and a half hour. Comment, view or do anything you want while waiting Link to comment Share on other sites More sharing options...
